Turf Tires
/ Turf Tires #1
kmarchin
I'd like to put turf tires on my Iseki TA-290.
Rear size is 12.4-26, front is 8-16.
I have not found tires this size except AG.
Are any other wheel sizes available ?
Will MF or any other wheels fit?
Thanks for the help.
/ Turf Tires #2
Ags and Turfs come in different sizes and use different rims. If you machine is 4WD make sure to maintain ratios.
Andy
/ Turf Tires #3
I'd just keep with the AGs.
It ain't a tractor without them.
/ Turf Tires #5
Sorry, I don't have an answer.
Thank God, someone out there knows the proper terminology.
Kudo's
/ Turf Tires
Thanks I didn't even consider the ratio's.
Someone has suggested light truck tires for the front but I seem to be striking out with the rear.
/ Turf Tires #7
Have you tried Firestoneag.com or miller tire, you might find something there. Either way maintain the rear overall height. Ask a dealer what was offered for a turf tire and go from there.
/ Turf Tires #8
I did some searching, and a John Deere 6405 uses 12.4-26 tires on the front. This may or may not help you.
You're right, though... That size is a little hard to find.
/ Turf Tires #9
Unfortunatly your SOL on the 26's for turfs, the first size offered in the R-3 Turf Design is 16.9/18.4 for the 26" wheel diameter. On the fronts u can convert to a 9.5-16 Turf and be within 7 % of the drive allowance in Overall Diameter. If interested reply and we can find u a 26" convert replacement set.
/ Turf Tires
Yes I'd like to do this.
One of my prmary functions of this tractor is mowing.
The AG tires are too aggressive.
/ Turf Tires #12
Unfortunately, you will probably have to find new rims to match your tractor. ag and turf rims just don't match up. I have turf tires on my small tractor and wish I had them on my tc40. My turf tires have always done everything I've asked them to do including pulling a 5' disc and they don't tear up the ground in the yard.
/ Turf Tires #13
If you are tearing up your yard with any tractor tire you are mowing when its too wet. I have mowed with ags for years with no problems unless I get lazy and mow when I should not be.
Chris
/ Turf Tires #14
You might see if you can find R4s in those sizes. They won't tear up the lawn like ags.
/ Turf Tires #15
*If you are tearing up your yard with any tractor tire you are mowing when its too wet.
**I have mowed with ags for years with no problems unless I get lazy and mow when I should not be.
Chris
*This will tear things up more than tire tread type.
**Exactly just takes a little common sense.
/ Turf Tires #16
The worst yard damage I've done was with the front turfs on one of my BXs.
/ Turf Tires #17
I agree with LB. If you have traction the tire will not slip. Therefore no damage to the lawn. If you turn sharp and depending on speed, yeah I you can rip the lawn with turfs or any bar type tire. It depends on what you want and conditions. I have a paved driveway and sand under the lawn, so I can get away with turfs. I have through plowed a 150 driveway with turfs in deep snow.
Personally though some slip is good for the drivetrain IMHO!;)
Dan
/ Turf Tires #18
Turf's are best for mowing; maybe that's why they are called turf tires??
If you still have any doubt; go to any golf course and see what they use.
I own a big fairway mower; so I can save you a trip.
/ Turf Tires #19
Yes, turfs are best for mowing. Here is the thing, its a tractor! Turfs are pretty much worthless on a tractor. Its like putting slicks on my F-350 4x4. Maybe its just me but I would not put turfs on any real tractor. They are great for things like the fairway mower or ZTR's
Chris
/ Turf Tires #20
Chris
U R rite if it's a tractor it needs Bar Tires.
Or with out AGs it ain't no tractor.
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A69167)
1997 KENWORTH T300...
121A (A63745)
121A (A63745)
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
