Turbo squealing
/ Turbo squealing #1
BlairK
Aubrey, Texas
Toolcat 5600
Hello all, I am having problems with my turbo squealing after i start my TC. It keeps squealing until I increase the RPM. Any thoughts?
Here is a picture of a typical day for my toolcat on our horse farm. That or hauling horse ****.
Thanks for all the great advise.
/ Turbo squealing #3
This is a stretch, but check the bolts that hold the exhaust pipe to the turbo flange if you see carbon smudging on the bottom of the bed/box.
/ Turbo squealing #4
If it is turbo squeal it would only do this a few times before it failed, then you would have black exhaust smoke and low engine power. Check belts including drive blet tension, the spring loaded idler may need to be set tighter to allow for belt wear.
6ft Bush Hog Rotary Cutter (A61166)
6ft Bush Hog...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2023 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2023 Ford F-350...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
2018 Jayco 264BH 29ft. T/A Travel Trailer (A61569)
2018 Jayco 264BH...
2009 BMW 750I Sedan (A61569)
2009 BMW 750I...
