Turbo RTV1100
   / Turbo RTV1100
TWO GUNS said:
mikeyd
Just talked to a man this morning, about his rtv 1100, subject was spark arrestors. I told him he should take it off. He said his didn't come with one. He even asked his dealer if he taken it off, and the answer was NO ...
Did your 1100 come with a spark arrestor, wouldn't they be at the end of the tailpipe like the RTV 900's ? ( am i going crazy or what ) Or would it be in the section that goes into the muffler from the tailpipe.... I thought all RTV's comes with spark arrestors !!! Or did the factory just forget to install one ~~~~~~ :rolleyes:
I had a spark arrestor on my machine. Removed and placed in trash w/i 15 minutes of ownership. Was inside the muffler.
   / Turbo RTV1100 #22
I'd rather be blown then stroked. ;)
   / Turbo RTV1100
Heres a couple pics taken outside before paint. The last few are of it painted.
   / Turbo RTV1100
Made the high mount air filter today. Here are pics beginning to end. Will clean up welds and paint it tomorrow. Can be used with turbo or in stock form. Total cost about $40.
   / Turbo RTV1100
Skipholiday said:
Engine stay pretty cool?
Looks nice~!
Engine Temp is normal. I installed the pyrometer bung but have not wired it yet. Will do that tomorrow. Exhaust gas Temp will be the true test. Theoretically, EGT should be lower than stock with a turbo unless the pump is cranked so high that your sending alot of unburnt fuel thru the exhaust. We'll see.
   / Turbo RTV1100 #27
miked,
You said the spark arrestor is " IN " the muffler, does he need to take out the two bolts holding the tail-pipe on , and does it just slide out of there ?
   / Turbo RTV1100
TWO GUNS said:
miked,
Thats exactly what he needs to do. The spark arrestor is attached right to the tailpipe. He will need to cut it off once he removes the tailpipe.
   / Turbo RTV1100 #29
Looks like a very nice job. I can tell, because it looks like even I could do it, and I KNOW that ain't the case! Very clean.
Have you thought about adding some insulation to the pipe to keep the pre-turbo heat (and velocity) ? How about an intercooler? Any idea on the EGT's yet?
jb
   / Turbo RTV1100
jb
Will know more tomorrow on EGT once I get the pyrometer wired up.
The air going in stays cold, especially now with the high mount filter, the air is traveling through a fair bit of steel pipe exposed to ambient air. I did consider an intercooler but don't know where I could put it. I thought about using a sidemount over on the intake side, but as this is an offroad machine that see's alot of mud I was worried about keeping it clean and it not getting beat up from offroading. The intercoolers are just as fragile as a radiator(or more) so it would need to be protected. Seemed like alot of hassle and I am satisfied with the setup now so I think I will leave well enough alone...for now.:D :D
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2003 Big Tex 10PI...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
