TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #1,001
just to keep this thread going. I have ordered a rebuild kit. I guess i could have sanded it down, but after 375 hours this mower really doesn't owe me anything. I've only ever changed belts on it. Mow 2 acres, once or twice a week for 11 years. Started getting bad after i dragged a harrow around for a while landscaping the front yard. Right after that the power was never the same and over the 3 years after that landscaping it was a struggle up any incline and it was hit and miss for power. If it was hot out forget it, the thing was like a turtle. Fall and spring were okay. I changed out to a heavier gear oil last week to see if i could salvage it, but it just made more noise than it ever did. Hoping this $450US dollar fix kit works. Here's some photos of what i pulled apart.
   / TuffTorq K46 Repair Guide with Pictures #1,002
Better to find a K66 from a junked tractor . The K66 will outlast the rest of the tractor . The Factory stock K46 is too flimsy unless it is upgraded to at least a K58 .
   / TuffTorq K46 Repair Guide with Pictures #1,003
It seems that we all have very similar experiences with these K46s. My Husqy 24K54 is a beast again with tons of power and I can mow seemingly an endless amount of lawn; and I've got probably the same 2 acre swath caddylover mentions.
If I learned anything at all, it's to NEVER tow anything more than ...70 - 80 pounds. I find it laughable that Husqvarna (which I LOVE) makes all these attachments for adding a snowblower attachment to the front and all kinds of weights to the wheels & rear. And that there's a place FOR a trailer to be towed around. But when I called Tuff Torq re the rebuild kit and got to chatting with them, they basically scoffed at the notion of anyone ever towing anything of weight in a machine with a K46. So, maybe a wagon full of leaves is all I'll ever tow again. I was blown away the other day when I drove up an almost 45 degree grade. The Husqy didn't even utter a noise, just surged right up. I rebuilt the tranny about 2 weeks ago at 437 hours. I have a feeling I should be good for a LONG time and don't need the power of a K66. (Admittedly, I'm in a VERY fortunate position to have inherited a 1983 Ford 1700 tractor a few years ago, with a backhoe attachment, which makes it incredibly easy for me to say how I'll never tow/haul anything with my Husqy ever again).
   / TuffTorq K46 Repair Guide with Pictures #1,004
My mistake was the harrow, should have never done it. Started slipping about 10 minutes into the drag. Figured i stretched the drive belt so i changed it out to new. Ran better, but then after the same amount of time was back to the slow mo. Changed the belt AGAIN and didn't harrow any more land. Got my buddy with a quad to do it which is what i should have done in the first place. NEVER load this tranny up. I'm 6'2" and 230 and that's probably too much for it, lol. Lesson learned.
   / TuffTorq K46 Repair Guide with Pictures #1,005
Cleaned.
   / TuffTorq K46 Repair Guide with Pictures #1,006
When my JD D140 had about 60 hours on it, I read a few posts on the K46 around here about how it came filled with 5W30 regular oil, but the manufacturer suggests 5W50 synthetic.
I was taking in my D140 to the JD dealer for something else, and I had them drain and refill the transmission with 5W50 Mobil 1 that I provided in a 5 qt jug. They did that, complained that the trasmission plug was not reuseable, but they had one lying around, and gave me back the jug about half full.
Right now I have 260 hours on the mower, and it is still running well.
It seems these are all problems with premature wear due to not putting in the right oil to begin with. Shame on JD. That's why I bought a different brand tractor when I decided to buy the real thing. I'm sure other brands cut costs too, but it seems JD is somewhat worse.
   / TuffTorq K46 Repair Guide with Pictures #1,007
Cleaned
   / TuffTorq K46 Repair Guide with Pictures #1,008
Wow, this thread has been ongoing for over 12 years! Many good advices here.
I am asking for help on behalf of my father: Recently he (again) broke a gear inside the K46 tranny (tried to pull a tonne of gravel up a hill). He dismantled it like last time, but this time around he had to dismantle the hydraulic engine as well, as the gear this time was the one attached to the disc brake, which is on the same axle as the engine.
I found the right gear for him and he assembled it on his own. Upon starting the engine and applying pressure on the pedal ... nothing at all happened, not even a tiny movement on the wheel axle. He was pushing forward and reverse quite a few times and then turned it off.
He dismantled all of it again, and realised that the small pin that supposed to lift the washer inside the hydraulic engine was missing - the one used to disengage the drive, and was later found at the bottom of the oil sump. So, he put back the pin and put all of it back together and tried again. Still no drive at all. After reasoning with him, we realised that with the pin missing, the drive should be working - it should be the other way around: Not possible to disengage the drive. So, the drive not working was not caused by the missing pin.
He dismantled it again and realised that the washer that the pin was supposed to push was missing. He just forgot to put it back the time before. He assembled it all again - still no drive.
I watched him following an instruction video on Youtube, and I could not see him going wrong anywhere, but the guy in the video mentioned something about the by-pass valves that I did not really got my head around. Mainly because I was not there when my father explained about a filter inside one of the valves.
I have a suspect that he might have lost some tiny part, like a ball inside a valve or something, but my workload is overwhelming me, so I do not have time to go there and have a look ... for the fifth time. Bless him, being over 80 years old, with an eyesight and hearing which have seen better days - I just wish he can get it working before I have to bring my own lawn tractor there, as the jungle is taking over their lawn more and more every day.
I have moved the transmission "backwards", i.e. turned the wheel axles, first one by one, then both, to test that the differential is working, and the transmission is working all the way to the hydraulic engine. From the other end, I have turned the belt wheel to confirm that the hydraulic pump is working, and it feels exactly as I expect it to do.
Are we just too shy when it comes to bleeding the pump/engine? Should we try for longer? When the (petrol-) engine is running and the forward/reverse pedals are pressed I can hear some kind of "rotating" sound from inside the transmission. Of course one would say, because something has to rotate inside as all is connected to the transmission.
I have read that some people first disengage the engine by pulling the thin thread-like handle that moves the arm and the pin inside the engine, push the forward/reverse pedals, and then re-engage the engine again, and repeat the procedure with the pedals. Would that make any difference?
Any thoughts, suggestions, or share your own aha-moments with me? I am out of clues now.
Thanks in advance //
Magnus
   / TuffTorq K46 Repair Guide with Pictures #1,009
hi all, kudos to the OP and all those that have contributed. i opened my k46, added the 2 drain plugs, filled with m1 15w50. only leaks were from me not tightening the drain plugs enough. have run ~50 hours, only 1 note i have to add.
i find that the sensitivity of the pedal over rough, bumpy land where my foot pressure varies is a new characteristic i don't recall with the factory fill. i may try a 5w50 or 40 next time.
   / TuffTorq K46 Repair Guide with Pictures #1,010
Many have a strut to control the input
434669 (A48836)
434669 (A48836)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2019 JOHN DEERE XUV835M LOT IDENTIFIER 25 (A53084)
2019 JOHN DEERE...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
