Tires Tubes in front tires
/ Tubes in front tires #41
J_J said:
Carl,
I believe that all the PT's should be able to do that. It's like the see-saw effect. If you can raise the front wheels off the ground about 6 to 10 in, you then you place a piece of a 8x8 or larger under the hydraulic tank and then let the front down. If you have more weight on the front, then it will raise the back wheels.
That's how ive done it with my 422.
/ Tubes in front tires #42
J_J said:
Carl,
JJ is correct -- at least on my older style 425. As long as I can get the timbers behind the hydraulic tank, it'll tilt forward enough to get the back wheels off the ground. I've done it more than once...
Another added benefit of doing this is that it essentially prevents trying to balance the rear of the PT on the head of a jack, while the PT is trying to oscillate on you. This solidly lifts both sides, without it "wobbling" from side to side...
/ Tubes in front tires #43
That's true too. When i went to change the back tire, i didn't even try to use a jack because it seemed like it would be pretty unstable. I could just imagine the jack shooting out from under the PT.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2014 Tesla Model S 60 Hatchback (A59231)
2014 Tesla Model S...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2023 RTVXG-850 SideKick (A61306)
2023 RTVXG-850...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
