Tube to hydro cooler cracked/leaking
   / Tube to hydro cooler cracked/leaking
I know this is an older post but, the same thing happened to me,
Now this is a steel pipe and it's solid on each end, if their is a vibration between the radiator and the transmition, something has got to give, so yes mine did crack also,
What I ended up doing was remove the pipe, blaze the fitting back on, the I cut the pipe in two, took 6 inch off the length of the pipi, braze 2 fitting on each end of the cut, then had a small 6 inch hydraulic line made and installed this in between my two halves, and re install, now their a rubber Hydraulic hose in the middle of this steel pipe, this hydraulic hose absorbs the vibration,
I hope I made this clear? If not ask me some questions.
Thnx
I ended up having it brazed. It's working well. The new part comes with a bracket to support the tube halfway between the two points. I haven't added a bracket yet; but plan to do so when it warms up a bit.
   / Tube to hydro cooler cracked/leaking #12
Hi,
I know this is an old post, just wondering how everyone made out with this problem?
I now have the same issue. I have a 2011 CK20S and the same line cracked for me. The pinhole crack is not right at the transmission, but about 6 inches down the line, headed toward the oil cooler. Its in a bend in the line. What are my options?
Should I try to track down the part and replace it? or take the line off and have it welded? Or is there some kind of patch I can use?
Bear in mind that my skills are limited to basically removing bolts, I have NO welding knowledge. The nearest dealer is a 3 hr drive away.
Here is the link to the part I found: Parts Finder Michigan Iron & Equipment Morrice, MI (855) 265-459
its part number 15.
Thank you
   / Tube to hydro cooler cracked/leaking #13
The new line is pricy, I haven't had it occur but If I did I would remove and acetylene weld. If you are unable take it to a shop somewhere. 20 minute or less job for a welder.
   / Tube to hydro cooler cracked/leaking #15
I'm having the same issue. I planned to take it off the line and have it brazed, but before I did, I figured I should ask someone that did it before, so I know what to expect....can I expect oil to come shooting out when I take it off? Should I worry about damaging o-rings? When I put my socket on it, it was very hard to turn, so I stopped trying. I'm going to post 2 pics, one of where it is attached to the transmission, and one where it connects to the line that comes from the oil cooler.
Is there anything I should be afraid of here? I lined up a local welder to bring the line to, he claims it should be a straight forward fix.
Any guidance would be appreciated here!
My fix has been very successful. I don’t recall how hard it was to remove. If I recall correctly I plugged the holes so I had very minor oil loss. There isn’t pressure in the line when the tractor is off and minimal when it is running.
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
