TU1700 Radiator
   / TU1700 Radiator #1
smcross9
I have a TU1700 that I have had for a while. The previous owner must have filled the radiator with tap water because the coolant is rust colored. I have flushed the radiator several times with no results. I have also used several flush products but the rust is still there. Does anyone have any suggestions.
   / TU1700 Radiator #2
The bottom of the block is full of rust. I would pull all of the freeze plugs and take a 1/8 inch rod and scrape the bottom of the water jacket while running water in it then use a pressure washer. when you have it clean that should be the end of the rust. I have done this several times and it works. If you have steel freeze plugs you might find they are in bad shape....Larry
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
