TU1700 Radiator
   / TU1700 Radiator #1
smcross9
I have a TU1700 that I have had for a while. The previous owner must have filled the radiator with tap water because the coolant is rust colored. I have flushed the radiator several times with no results. I have also used several flush products but the rust is still there. Does anyone have any suggestions.
   / TU1700 Radiator #2
The bottom of the block is full of rust. I would pull all of the freeze plugs and take a 1/8 inch rod and scrape the bottom of the water jacket while running water in it then use a pressure washer. when you have it clean that should be the end of the rust. I have done this several times and it works. If you have steel freeze plugs you might find they are in bad shape....Larry
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
Unused Delta Crash...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
