TU 1700 Hard to Start
   / TU 1700 Hard to Start #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Just purchased TU 1700 this past Friday. Started right up first time removing it from trailer. Turing key to left heats resister to a glowing red in about 30-40 sec. Glow plug bar has about 9 volts across the bar. Contacted seller he stated full throttle then back off 1/4. Live in VA and weather has not been very cold to date. First glow plug would be easy to replace but other 2 seem to are located behind part of the fuel system. Will a inline heater or dipstick heater or help with this problem? By the way, I'm a novice.
   / TU 1700 Hard to Start #2
Don't replace them unless they are not working. I install water heating devices on my tractors.
Thanks for the reply, I do have one question, with this tractor there is very little space to hook an inline heater. The lower radiator hose is only about 4-5" long and bent in the middle. The oil dip stick is 5-6" long, can I insert a long dipstick heater into the block?
   / TU 1700 Hard to Start #5
They do a good job of heating the oil, but that doesn't heat the block & cylinders, which is what you want heated. i can probably supply a freeze plug heater that will fit your tractor.
I tried a dipstick heater today, it did not work. How hard is it to remove a freeze plug and install a block heater? Like I said earlier, I'm a novice. Do you carry glow plugs?, and need manuels for this tractor any suggestions?
Well, some times life is good, sometimes it not. Got tractor started today with the help of a Mr. Buddy propane heater. Ran for about 30 min, I got off and let it idle for 15-20. Started to work with rock rake in drive and all of a sudden it lost power, started skipping and cut off. I let it set for a few min, checked the oil, it was ok. It started and made it back to house. After getting it into garage noticed it was hot. Hope I haven't fried it. Seems to be full of anitfreeze. Any suggestions.
   / TU 1700 Hard to Start #8
thermostat?
   / TU 1700 Hard to Start #9
Sounds like a dirty fuel filter or gelled diesel.
Thanks for all the suggestions, I appreciate it. Could a fuel filter or gelled fuel cause hard starting and most important the tractor to run hot?
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
