TU 1700 Hard to Start
   / TU 1700 Hard to Start #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Just purchased TU 1700 this past Friday. Started right up first time removing it from trailer. Turing key to left heats resister to a glowing red in about 30-40 sec. Glow plug bar has about 9 volts across the bar. Contacted seller he stated full throttle then back off 1/4. Live in VA and weather has not been very cold to date. First glow plug would be easy to replace but other 2 seem to are located behind part of the fuel system. Will a inline heater or dipstick heater or help with this problem? By the way, I'm a novice.
   / TU 1700 Hard to Start #2
Don't replace them unless they are not working. I install water heating devices on my tractors.
Thanks for the reply, I do have one question, with this tractor there is very little space to hook an inline heater. The lower radiator hose is only about 4-5" long and bent in the middle. The oil dip stick is 5-6" long, can I insert a long dipstick heater into the block?
   / TU 1700 Hard to Start #5
They do a good job of heating the oil, but that doesn't heat the block & cylinders, which is what you want heated. i can probably supply a freeze plug heater that will fit your tractor.
I tried a dipstick heater today, it did not work. How hard is it to remove a freeze plug and install a block heater? Like I said earlier, I'm a novice. Do you carry glow plugs?, and need manuels for this tractor any suggestions?
Well, some times life is good, sometimes it not. Got tractor started today with the help of a Mr. Buddy propane heater. Ran for about 30 min, I got off and let it idle for 15-20. Started to work with rock rake in drive and all of a sudden it lost power, started skipping and cut off. I let it set for a few min, checked the oil, it was ok. It started and made it back to house. After getting it into garage noticed it was hot. Hope I haven't fried it. Seems to be full of anitfreeze. Any suggestions.
   / TU 1700 Hard to Start #8
thermostat?
   / TU 1700 Hard to Start #9
Sounds like a dirty fuel filter or gelled diesel.
Thanks for all the suggestions, I appreciate it. Could a fuel filter or gelled fuel cause hard starting and most important the tractor to run hot?
12in Backhoe Bucket (A52748)
12in Backhoe...
2018 INTERNATIONAL BOX TRUCK (A52472)
2018 INTERNATIONAL...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
