TU 1700 Hard to Start
   / TU 1700 Hard to Start #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Just purchased TU 1700 this past Friday. Started right up first time removing it from trailer. Turing key to left heats resister to a glowing red in about 30-40 sec. Glow plug bar has about 9 volts across the bar. Contacted seller he stated full throttle then back off 1/4. Live in VA and weather has not been very cold to date. First glow plug would be easy to replace but other 2 seem to are located behind part of the fuel system. Will a inline heater or dipstick heater or help with this problem? By the way, I'm a novice.
   / TU 1700 Hard to Start #2
Don't replace them unless they are not working. I install water heating devices on my tractors.
Thanks for the reply, I do have one question, with this tractor there is very little space to hook an inline heater. The lower radiator hose is only about 4-5" long and bent in the middle. The oil dip stick is 5-6" long, can I insert a long dipstick heater into the block?
   / TU 1700 Hard to Start #5
They do a good job of heating the oil, but that doesn't heat the block & cylinders, which is what you want heated. i can probably supply a freeze plug heater that will fit your tractor.
I tried a dipstick heater today, it did not work. How hard is it to remove a freeze plug and install a block heater? Like I said earlier, I'm a novice. Do you carry glow plugs?, and need manuels for this tractor any suggestions?
Well, some times life is good, sometimes it not. Got tractor started today with the help of a Mr. Buddy propane heater. Ran for about 30 min, I got off and let it idle for 15-20. Started to work with rock rake in drive and all of a sudden it lost power, started skipping and cut off. I let it set for a few min, checked the oil, it was ok. It started and made it back to house. After getting it into garage noticed it was hot. Hope I haven't fried it. Seems to be full of anitfreeze. Any suggestions.
   / TU 1700 Hard to Start #8
thermostat?
   / TU 1700 Hard to Start #9
Sounds like a dirty fuel filter or gelled diesel.
Thanks for all the suggestions, I appreciate it. Could a fuel filter or gelled fuel cause hard starting and most important the tractor to run hot?
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
