Tiller TSC tiller
/ TSC tiller #1
deere_x475guy
Eaton Rapids, MI
JD 4110
I just called around and TSC has a 4' pto driven tiller. Does anyone have experience with this tiller? They tell me it has gears instead of a chain. Is the gear a better way to go? What sort of shear pin protection does it have?
Thanks
Bob
/ TSC tiller #2
BOB ,
I didn't know TSC had a 4' tiller. What kind of price did they give you. A 4' is about what I am looking for. Could you offset the tiller?
From what little I know the gear drive is supposed to be better than chain drive(more durable). Most of the tillers have a slip clutch instead of a shear bolt for protection. Maybe someone with more experience can confirm my thoughts
Chris
/ TSC tiller #3
THe TSC tiller is a King Kutter.
/ TSC tiller #4
I noticed your tillers come with, depending on the size, a #4, 5, 6 or 8 PTO. What does that mean? Isn't the pto splined shaft a universal size?
/ TSC tiller #5
Yes a standard 540 RPM PTO shaft on the rear of a tractor is 1 3/8" 6 spline. The size # shaft mentioned is the category # or HP rating of the shaft we supply with the tillers. Like a fertilizer spreader will come with a category 1 or 2 most of the time where a 90" tiller will require a #6 or #8 because the HP demanded by the 90" tiller is much greater than the fertilizer spreader.
/ TSC tiller #6
</font><font color="blue" class="small">( A 4' is about what I am looking for. Could you offset the tiller? )</font>
Yes, it is offset. Unfortunately, that's all I was able to find out. I have no idea about the size of the offset or the method of offsetting.
Some just move the mounts, some move the gear head with a telecopic shaft to the side gears, and some have a gear head that the shaft passes right through so the head can be slid down a fixed shaft.
It might be different now, but the 4' and 5' KK tillers were both going for the same price when I bought my 5 footer.
Sam
/ TSC tiller #7
I was just going to put a link to Carter & Carter Machinery but I see he beat me to it.I just bought a 42" from them to use with my BX1800 for our garden and I am very satisfied with it.Does a good job and looks like its very well built.For the money these are it.
/ TSC tiller
the 4' is running $999.00 and I still have to find out if it will shift to the side or not. I hope to go back this evening and I will let you know. I know the flyer doesn't say anything about shifting.
/ TSC tiller #9
CCM (carter and carter) tiller will shift to the side 4" by moving the hitch blocks, and costs around the same depending on where you live. Mark says he can ship me a 49" CCM gear drive for $1000 to Florida. That's a good deal. John
/ TSC tiller #10
</font><font color="blue" class="small">( ...I still have to find out if it will shift to the side or not. )</font>
It does...I just don't know what method they use. If you need further evidence, check out The KingKutter Tiller Page.
Sam
/ TSC tiller #11
My neighbor has one that I use every so often. Works pretty good. I have no complaints and has been free. Even though I do give him some money for using it. He says don't pay him but I give him some anyway.
murph
/ TSC tiller #12
Also, I just noticed you have a 2210...since it's a sub-compact you might need to consider the weight. Even the 4' KK Tiller is 600 lbs...and that's without any soil sticking around the frame. There are others MUCH lighter.
My Kioti (roughly 2100 lbs) can get a little tippy even with about 140 pounds on the front when I accelerate too quickly with the 690 lb 5' tiller on back.
Sam
/ TSC tiller #13
Let TBN users know if you ever plan to open up or partner with a West Coast distributor.
I have a rotary mower and a rototiller, but your equipment is so top notch I know I would buy something from your company!
'Buster"Sherwood, Oregon
/ TSC tiller #14
<font color="blue"> The 4 ft model is offset to eliminate tire tracks </font> (Quote from KK web site)
There were 4 foot models at TSC when I bought a 5 footer a couple weeks ago. I may be wrong, but I think the 3pt frame on the 4 foot tiller is off center, so one tire track is covered with each pass. Is that right??
<font color="blue"> with the 690 lb 5' tiller on back. </font>
So, did you get the 5 footer?? Somehow, mine doesn't seem that heavy, but that's what the website says it weighs. (I haven't tried picking it up!)
OkieG
/ TSC tiller #15
</font><font color="blue" class="small">( So, did you get the 5 footer?? Somehow, mine doesn't seem that heavy, but that's what the website says it weighs. (I haven't tried picking it up!)
OkieG )</font>
I did get the 5 footer about two months ago, and I haven't ever verified the weight...but the only impliment I have that makes my CUT more tippy is my 4 foot heavy duty scoop with a heaping load of sand. Fortunately for both my CUT and me...I only go VERY SLOW to till /forums/images/graemlins/wink.gif
Sam
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
(10) Field Cultivator Shanks (A65640)
(10) Field...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
John Deere 2840 Tractor (A64047)
John Deere 2840...
