SylvainG
Platinum Member
This is the KB2365 backhoe hydraulic diagram according to Kioti. To me, it doesn't make any sense! Does it makes sense to you?
If you look at the P side of things, all valves but the last one have PB capability but the last one is connected to a blocked port when in neutral? This would mean that unless a joystick is activated, all fluid has to go through the relief valve. What???
Second, beside the Dipperstrick tank port which goes to tank, all the other tank ports are connected together and... that's it??? How is the hydraulic fluid supposed to make its way back to the tank???
What is going on here?!? Am I missing something obvious here or was the person that drew this on drug or what???
BTW, I looked at the KB2475 diagram and it's exactly the same.
