Trying to ID thos subsoiler
   / Trying to ID thos subsoiler #1
HUTCHAMUSPRIME
Ford 5000, 8n sidemount, 4500 backhoe
I need a replacement part for this subsoiler. I know this just a peice of steel but if I could find a replacement instead of having to cut and drill holes in a new peice of steel I'd prefer it. It had blue paint on it at some point. Thanks!
What part?
If you look at the first photo, where the top link connects to implement there should be 2 peices of steel there and the top link goes between and then your pin holds it all. One of those peices is broken down probably 14-16 inches. It bolts on so I was hopping to get a pre drilled replacement part but if not I'll appreciate the advice on tracking down the right peice of steel to fab. I just don't know that much about steel. Lol.
how worn down is it? need measurements for holes....
Sorry I wasn't very specific on what part I was looking for! Its on the connecting peices for the top link. I don't know what it's called! Check the first photo and look at the top link and you'll see what I mean. It looks to have broken off about 14 inches or so down.
It almost looks like a dearborn lift type subsoiler.
What part?
I found a diagram finally! It looks like it's called the "top link bracket" it looks like a dearborn 10-89 lift type subsoiler.
(2) OIL DRUMS & PUMP (A58374)
(2) OIL DRUMS &...
1769 (A58375)
1769 (A58375)
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2019 F150 (A56438)
2019 F150 (A56438)
BIMINI TOP FOR BOAT (A58374)
BIMINI TOP FOR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
