Trying to find Bobcat 334 control relief valve-6670134
   / Trying to find Bobcat 334 control relief valve-6670134 #11
I could get you a new valve for $600 that's 50 bucks off, or anybody else that ever needs special parts just pm me
Is that per side, or for a pair?
Thanks a bunch JackinVT!....good to know once you got them off it was a simple matter to install new ones.
I'll probably have to redo hose lines on mine.
And thank you Mogoman for info!
Best
Melli
   / Trying to find Bobcat 334 control relief valve-6670134 #12
I was wondering to limit the corrosion issues in future, if putting on Anti-Ox (used for electrical connections on Al wire) on shaft bolts would be helpful in limiting electrolytic corrosion. On mine it looks like water and salt got in housing and is fusing bolts to relief block.
   / Trying to find Bobcat 334 control relief valve-6670134 #13
Best
Melli
per side
   / Trying to find Bobcat 334 control relief valve-6670134 #14
Just a heads up.. No one is saving these old, corroded, leaking, over priced aluminum relief valve blocks anyway. So just use a dremel to cut reliefs around all 4 cap bolts right into the block. It allows the penetrating oil to get around the heads, which are packed with corrosion. Once you get oil in there they spin right out. I've done 1, and about to do my second.
Question: Anyone have luck with aftermarket relief valve blocks? I hate shelling out 9 bills for a bobcat one.
Front End Loader Joystick and Pump Sprayer (A54865)
Front End Loader...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
Hose Reel (A55758)
Hose Reel (A55758)
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2430 (A51248)
2430 (A51248)
