Trying to find Bobcat 334 control relief valve-6670134
   / Trying to find Bobcat 334 control relief valve-6670134 #11
I could get you a new valve for $600 that's 50 bucks off, or anybody else that ever needs special parts just pm me
Is that per side, or for a pair?
Thanks a bunch JackinVT!....good to know once you got them off it was a simple matter to install new ones.
I'll probably have to redo hose lines on mine.
And thank you Mogoman for info!
Best
Melli
   / Trying to find Bobcat 334 control relief valve-6670134 #12
I was wondering to limit the corrosion issues in future, if putting on Anti-Ox (used for electrical connections on Al wire) on shaft bolts would be helpful in limiting electrolytic corrosion. On mine it looks like water and salt got in housing and is fusing bolts to relief block.
   / Trying to find Bobcat 334 control relief valve-6670134 #13
Best
Melli
per side
   / Trying to find Bobcat 334 control relief valve-6670134 #14
Just a heads up.. No one is saving these old, corroded, leaking, over priced aluminum relief valve blocks anyway. So just use a dremel to cut reliefs around all 4 cap bolts right into the block. It allows the penetrating oil to get around the heads, which are packed with corrosion. Once you get oil in there they spin right out. I've done 1, and about to do my second.
Question: Anyone have luck with aftermarket relief valve blocks? I hate shelling out 9 bills for a bobcat one.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
New/Unused CFG Industrial MX12RX Mini Excavator (A54865)
New/Unused CFG...
