Tractor Sizing Trying to decide - B2601 or B2650
   / Trying to decide - B2601 or B2650 #1
Dexterous
Grove City, PA
2019 Kubota B2650
Guys,
I have 13 acres of mostly woods and just enough grass for a push mower (no tractor mowing needed). The property has lots of water issues and trails that need constant maintenance. I also have 200 yard long, crushed limestone driveway with a large parking lot like area near my garage
I currently own a BX23S front loader / backhoe combo and it works really well but its a bit small for what I do. I purchased my BX in 2017 because I thought I wanted a small tractor that could fit into tight places. This happens on occasion but I am more often wishing for a machine with more loader/backhoe power.
I almost exclusively use the font loader and backhoe (no mowing). My very near-term projects include digging a hole for a swimming pool, digging several ditches, driveway maintenance with 2A stone and digging a deep garage addition footer. If I had a machine that could do it, I would also dig up a few stumps around the house as needed. In the winter, I blow my driveway with a rear blade but at 200 yards, wet, heavy snow can be a challenge.
I would just go for the 2650 but I am a bit concerned that I will find it physically too big to easily drive through the woods. ON the other hand, I am worried that there wont be enough difference between the BX23S and the BX2601. I suppose I could cut a few trees and widen my trails if needed but I would only do that if I couldn't get past.
Any thoughts and advice are welcome! Thanks.
   / Trying to decide - B2601 or B2650 #2
Went through the same steps in machines and concern as you outlined. I would suggest going with the B2650. With your property and projects the B2601 BH you stated as a concern is correct.
...had a Massey gc2310 (excellent scut btw), a B2920/bh65 and current B3300/bh77.
The 2650 will Not be too big in the woods or on your property. I had same concern and it was unwarranted.
   / Trying to decide - B2601 or B2650 #3
We run a L3000DT in our woods;no problem.Foot print between the B2650/L2501 aren't that much different.Cost wise the B2601/B2650 and L2501 are close.There is a reason the L2501 is the hottest selling tractor for Kubota right now.
   / Trying to decide - B2601 or B2650 #4
I currently own a BX23S front loader / backhoe combo and it works really well but its a bit small for what I do. I purchased my BX in 2017 because I thought I wanted a small tractor that could fit into tight places. This happens on occasion but I am more often wishing for a machine with more loader/backhoe power. I almost exclusively use the font loader. No grass mowing.
VIDEO: Kubota B26�1 VS Kubota B265� - YouTube
You should also consider Kubota's B26, the lightest of Kubota's "commercial" T-L-Bs.
VIDEO: Comparing Kubota TLB series tractors(B26, L47, M62) - YouTube
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
So you want to TRADE UP for a new Tractor? - TMT - YouTube
Five reasons owner/operators trade up from Subcompact Tractors:
More tractor weight.
More FEL lift capacity.
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
Larger wheels and tires yield more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris with less operator perturbation.
   / Trying to decide - B2601 or B2650 #5
I was faced with the same situation 3 years ago. I bought the B2650 and never regretted it.
   / Trying to decide - B2601 or B2650 #6
B2601 is not much of a jump from a BX, so I'd go B2650. May also want to consider an L2501/3301.
Thanks guys! I think i will go with the B2650.
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2015 BIG TEX FRAC WATER TREATMENT TRAILER (A55745)
2015 BIG TEX FRAC...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
