Trying the tire grooving for next mod
   / Trying the tire grooving for next mod #1
High Compression
Platinum Member
De Soto, KS
Kubota M7060HDC12/ Kubota ZD21 pro60
Hey all. Going down my list of mods. Grooving the tires for the winter traction was pretty important to me. All of my other tractors that I have owned in the past and used to push snow with had turf tires. They always gave me excellent traction even in icy conditions. Enough to push a full blade on ice. I learned that they would be difficult to get and a long wait for turf tires on the Grand L. So I decided to try grooving. I bought my groover on ebay with #4 (approx. 1/4") blades and gave it a shot. It was a lot easier than I expected. I did try something a little different than others that I had seen. Using the theory that more biting edges are beneficial in the snow and ice, then I decided to put 2 small grooves on the back lugs instead of one larger one. We'll see. Snow is missing us this year. Last year at this time we had over 40". This year .5" Anyway, here are some pix. Enjoy.:thumbsup:
   / Trying the tire grooving for next mod #2
Nice looking tires, I like the double grooves.
   / Trying the tire grooving for next mod #3
Very nice job, looks like it was done at the factory!
   / Trying the tire grooving for next mod #4
Looks nice! I imagine that took more than a few hours.
Thanks. I thought I'd give them a try.
Thank you. That was my intention second to better traction.:laughing:
Well I didn't really time myself. I know the fronts only took an hour. For the back, since I wanted to use the double grooves, and the the treads are asymmetrical I made a cardboard template. So if you include the making of the template and the grooving time, i would guess 1.5-2
hrs on the back. So not terrible. And I didn't do them at the same time. I did the fronts one evening and backs another day. In my opinion, well worth the time. :)
   / Trying the tire grooving for next mod #6
High Compression: I posted on another thread about grooving, aren't you concerned with tearing up the tires? I own rubber tracked machines and have seen the damage that can happen with chunks ripping off. Seems like you'd be opening yourself up to a possible rubber chunker looser{:)}, just a thought.
I also live where there is a lot of ice this time of year{especially this year} and will say I don't care how many grooves are in a rubber tire it aint going to make a lick of difference on traction. The only thing that will help would be chains cleats or studs.
   / Trying the tire grooving for next mod #7
That looks pretty good. I haven't had a traction issue with mine but it gave me an idea for some other applications. Good job my friend :thumbsup:
   / Trying the tire grooving for next mod #8
And I thought you did it free hand!!! Lol
   / Trying the tire grooving for next mod #9
Great job. Looks good:thumbsup:
I too have owned many pieces of equipment with rubber tracks. 4 mini excavators, 1 mid size excavator and 3 directional bore machines. I know what your saying. But tracks and tires are apples and oranges.
On the flip side, if a tire doesn't spin due to loss of traction, it can't rip it's self apart. There is another TBN'r that posted his tires after a year of use with the tires grooved and I would say that they were less worn after 400 hrs, than if they had not been grooved. I'm sure that if you groove too deep and also cut all the way through the ends of the lugs, that you would open yourself up to potential damage, but we'll see. I generally put about 250 hrs per machine per snow season, so I will post pix in a year or so. If it tears up my tires, I will be sure to let all the TBN'rs know that it is a potential risk. All I know is that I can not complain one bit about a loaded turf tire on snow and ice. All of those biting edges do make a difference, and they have been giving me enough traction on ice to push a plow full for years. They also wear well because I'm not spinning the whole time.:cool:
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2017 Ford F-250 (A55973)
2017 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
