True 3rd function or diverter valve for grapple?
   / True 3rd function or diverter valve for grapple? #71
Regen works faster than direct flow.
That's what people say but that is certainly not my experience. My plow angles super slow in the dump regeneration direction and my grapple closes like molasses is the hydraulic fluid in the regeneration direction. Both attachments operate MUCH faster in the curl non regeneration direction.
   / True 3rd function or diverter valve for grapple? #72
Well, you have a kubota. I guess they're not cats meow after all. ;)
Regen is first stage on that right? You have to push past it to get into direct port fed?
   / True 3rd function or diverter valve for grapple? #73
Unfortunately my FEL valve is regen ONLY. It does not have a 4-position curl/dump circuit. :(
ac
   / True 3rd function or diverter valve for grapple? #74
I'd be swapping out to a better valve.
   / True 3rd function or diverter valve for grapple? #75
How do you like it on the lift?
It's fine ... just have to remember to return the joystick to neutral before you let off the button.
Mainly forming a habit, so you are doing it without even thinking.
I do like having the curl function available at the same time.
What setup is more natural? Forward to close grapple?
That's how I felt about it:
Forward to lower the FEL, forward to lower the lid/jaw.
Back to raise the FEL, back to open the lid/jaw.
Originally had the hoses for the grapple reversed so that it was opposite, decided that was counter-intuitive and I ought to change it before it became a habit.
John Deere 5055E (A53317)
John Deere 5055E...
JOHN DEERE TRACTOR (A57192)
JOHN DEERE TRACTOR...
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
1537 (A57192)
1537 (A57192)
2016 International WorkStar 7400 21ft Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
