True 3rd function on MT 357?
/ True 3rd function on MT 357? #2
I don't see why a WR Long couldn't be installed.
Thanks guys...looks like these are both using the "power beyond" port on the tracker so that all 3 functions can be used at the same time. Where is the "power beyond" port on the MT series?
Another note...neither of the above kits are designed to work with tractors that have cabs
/ True 3rd function on MT 357? #5
MT240
My dealer is researching a true after market 3rd function that is not a diverter...I called a dealer in Tomball TX and they do them every day...so someone makes them. The ones they put on have 2 buttons, not just a single button to divert.
The only question they had for me was "does it have a cab or not?" apparently they use different products for cab or no cab
/ True 3rd function on MT 357? #7
doesn't matter if it's a cab or not . your mounting you valve and hoses outside the cab
and running your button inside to work off of your level arm
Dealer found one from WR long...but I am leaning toward the T494 now.
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
20x20 Car Port (A65640)
20x20 Car Port...
2020 Big Tex 16TL20 20' Tilt Trailer (A64127)
2020 Big Tex...
Unverferth Perfecta II (A64126)
Unverferth...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
