Trucking marble. Not much room for error here.
   / Trucking marble. Not much room for error here. #1
alchemysa
South Australia
Kubota B1550HSD
The real fun begins at about 6:00. At about 9:00 they have to start going down backwards. At 10:00 its still a long way down.
Carrara le cave - YouTube
   / Trucking marble. Not much room for error here. #2
Oy! Engage sphincter muscles .....
   / Trucking marble. Not much room for error here. #3
Even without errors wow!! How about a nice little earthquake halfway home from work!!!
   / Trucking marble. Not much room for error here. #4
The backward trek is definitely precarious. I tip my hat to those truck drivers.
   / Trucking marble. Not much room for error here. #5
Wow, crazy way to make a living!!!!
   / Trucking marble. Not much room for error here. #7
Earthquake? How about even a dusting of snow. :eek:
   / Trucking marble. Not much room for error here. #8
This job separates the men from the boys for sure. I've been a truck driver for 32 years now and been in some hairy situations not quite that extreme but bad enough. It takes all kinds so next time you see a trucker count your blessings and say a prayer for that person . . .John
   / Trucking marble. Not much room for error here. #9
Good Lord, imagine if you lost your brakes. It would be a bad day.
   / Trucking marble. Not much room for error here. #10
Burning up the brakes would be a really bad day. Stuck between gears would be a really bad day. Loosing air and having the brakes set up would be a really bad day. A dunnage or tiedown failure would be a really bad day. A blowout on the steering axle(s) would be a really bad day.
I see lots of opportunities to have a really bad day at the quarry here.
2013 Ford F-250 Crew Cab Pickup Truck (A56858)
2013 Ford F-250...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
LOT: (2) Komatsu Part # 207-70-73210, (2) Komatsu Part # 208-70-73220 (A59076)
LOT: (2) Komatsu...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
