troybilt super bronco
/ troybilt super bronco #1
randy41
Veteran Member
Linden VA
the tiller tines quit turning. the wheels still turn. so this seems to be a stripped gear problem on the tine shaft. anyone ever fix this? looking for tips and tricks to make this go smoothly and for me to end up a happy tiller user.
/ troybilt super bronco #2
could be a sheared key in the bronze tiller shaft gear, or could be the teeth on the gear are broken. May even have to replace the shaft that runs the gear. Before removing the tine shaft check to see if there is wiggle in the shaft. If so then you will also need to replace the tapered roller bearings while you at it. if the seals have cut in the shaft then will also need to replace the shaft due to that is where the rubber part of the seal runs. have replaced several over the last several years in the shop.
Tarter 3pt 5' Landscape Rake (A64912)
Tarter 3pt 5'...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2001 STERLING LT7500 SERIES (A67714)
2001 STERLING...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
