Thanks all. Progress has been made by the time tested application of a hammer. Some light tapping on the bottom of the shift lever accompanied by rocking the tiller back and forth on the non turning wheels freed things up! Yea! Now, why did that happen? Of note, when the shift lever is all the way up, and I roll the thing, there is some internal clicking noise. With the shift in the neutral/level position, no clicking and free rolling. Ideas?
I have a horse of some description, having looked at several manuals on line I have not found one that looks exactly like mine. It appears that a call to Troybilt HQ ID Team will be the next step there. Found the serial number (241981) with arrow cast into the housing, but model decal is mostly obliterated.
On the manuals I did look at they recommend checking the tranny oil. I see the drain plug, and the vent plug, but on place to check. I don't want to risk running the thing until I verify the tranny oil level. Also regarding oil levels, the manuals are not clear to me at least as to what position the tiller should be in while checking the oils. Level I presume, but ???
Some wisdom if you please....
TIA,
Dennis
