Troy built Horse problem
/ Troy built Horse problem #1
DeNiro
Raleigh, NC
Kioti KL3054 / Iseki TL2100
I just noticed the belt pulleys on the front of transmission will move in and out about 1/4". I was changing belt positions when I noticed it. What is the problem and it is easily fixed?
This is the four speed model.
/ Troy built Horse problem #2
They all move. I think for alignment purposes. Not a problem.
/ Troy built Horse problem #3
Just got a used Horse myself. Read through the manual and that movement is normal. It allows for shifting between Fwd and Rev and between the Hi and Low gear by sliding the belt over. Unless the belt is stretched too much, then it might need to be replaced. You can also adjust the tension. Might want to check the manual for that.
HYUNDAI HL955 WHEEL LOADER (A65056)
HYUNDAI HL955...
2018 DODGE CHARGER (A66091)
2018 DODGE CHARGER...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
2016 Ford Escape SE SUV (A66738)
2016 Ford Escape...
