Troy built Horse problem
   / Troy built Horse problem #1
DeNiro
Raleigh, NC
Kioti KL3054 / Iseki TL2100
I just noticed the belt pulleys on the front of transmission will move in and out about 1/4". I was changing belt positions when I noticed it. What is the problem and it is easily fixed?
This is the four speed model.
   / Troy built Horse problem #2
They all move. I think for alignment purposes. Not a problem.
   / Troy built Horse problem #3
Just got a used Horse myself. Read through the manual and that movement is normal. It allows for shifting between Fwd and Rev and between the Hi and Low gear by sliding the belt over. Unless the belt is stretched too much, then it might need to be replaced. You can also adjust the tension. Might want to check the manual for that.
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A48837)
New/Unused 20ft...
INTERNATIONAL 786 TRACTOR (A50459)
INTERNATIONAL 786...
Warren Spreader Bed Insert (A48837)
Warren Spreader...
2000 Ford F-350 Pickup Truck (A48081)
2000 Ford F-350...
2014 GMC Terrain SLE2 SUV (A48082)
2014 GMC Terrain...
2013 Mack CHU613 Day Cab Truck, VIN # 1M1AN07YXDM014973 (A48836)
2013 Mack CHU613...
