Troy-Bilt Tine Assistance
   / Troy-Bilt Tine Assistance #1
jjinva
Victoria, VA
John Deere 650
I have an old Troy-Bilt Horse rear tine tiller and it's been working fine up until today. I was tilling my garden spot and one of the tines fell off (the right one, if standing behind the tiller). No big deal I thought so I put the bolt back in through the tine and attached it back to the tiller.
The tine spins fine when it's not under any load but when I put it back on the ground the left tine spins like normal but the right one (the one that fell off) doesn't want to turn. I backed off the bolt a little thinking maybe I overtightened it but that didn't help. Should I loosen it more or is there another trick or something I can try? Any help is greatly appreciated. Thanks
   / Troy-Bilt Tine Assistance #2
Sounds like you lost the key on the right side. Take the right side off and you should see a key in the slot on the tine shaft.
Okay great, thanks so much!
   / Troy-Bilt Tine Assistance #4
When the tine holder and tines fell off the key went also but you didn't see it. Take the other side off and take that key to a hardware store with you and buy one like it to replace the missing key and your back in business for less than $1.00. I take my tine holders off each year and and clean and grease the shafts, if you don't they tend to rust tight
Steve
2003 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2003 TRAVIS BODY &...
20704 (A55853)
20704 (A55853)
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2014 International Bucket (A55973)
2014 International...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
