Troy Bilt Cultivator
   / Troy Bilt Cultivator #11
a cultivator is used for after u plant ur crops u use it to keep the ground inbetween the rows loose so the grass wont take over the plants and a tiller is used to prepare the ground before u plant ur plants u can use a walk behind tiller to cultivate with but a tractor tiller would be to wide to fit between the rows and if u take the shovels of a cultivator u can use it only after u dics u use it the break the soil below where u disc to make it where water will raise to the plants when its dry and will go done when its raining so it wont flood the plants and when u do this the cultivator would be call a chisle plow
   / Troy Bilt Cultivator #12
When I take the shovels off my cultivator, I can dig it down a foot, in raw ground, it will pull all the roots and big rocks out of the ground. It might not be made for that but it works really good. I should get a single tooth ripper, as my cultivator is a little small for my tractor.
David-Davies
   / Troy Bilt Cultivator #13
David-Davies
Got a picture of what your cultivator looks like?
   / Troy Bilt Cultivator #14
I'm sorry that I don't know how to up load pitchers, BUT I put a pitcher on my profile, of my cultivator, or what I think is a cultivator. let see what happens.
David-Davies
   / Troy Bilt Cultivator #16
yes that is a cultivator it is a regid shank cultivator i believe they work the best
   / Troy Bilt Cultivator #17
Looks kinda like the scarrafiers on a box blade without the box.
To upload pictures, There is a symbol of a paper clip at the top of the dialog box when you are typing your post. Click on it and it will open a window which will allow you to browse for your pictures. After selecting your pictures (4 at a time), click the upload button and then either select up to 4 more or close the window.
Just got back in town.... Troybilt calls their small tiller a cultivator. It's like the Mantis advertised on tv. It's small enough to get between plants for weeding. I just never ran it more than a few minutes to get it hot the first few years. When I did, the gaskets blew. Of course, out of warranty....
Thanks,
David
   / Troy Bilt Cultivator #19
Thanks,
David
Glad to see you back. Hope you didn't mind my borrowing your thread while you were gone. I've actually learned quite a bit.
I've seen the ads for the mantis and thought about getting something like that for after the garden is planted. My tiller/cultivator is too big to use after you've planted (see pic). How do you like yours for between the plants?
Our cultivator is the Troybilt TB144. It sells for around
$299.00 now. We paid $100 less at Tractor Supply without the attachments or manuals. It seems to run ok now that I have the cam timing correct. Gets in tight to the plants without chewing up the tops or roots. Good for loosening the soil for potato hilling. Also have a Troybilt economy 6 hp tiller (circa 1973), that works great, but tears up the plants if I get too close.
David
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2014 Chevrolet Express 2500 Cargo Van (A50323)
2014 Chevrolet...
