whodat526
Veteran Member
a cultivator is used for after u plant ur crops u use it to keep the ground inbetween the rows loose so the grass wont take over the plants and a tiller is used to prepare the ground before u plant ur plants u can use a walk behind tiller to cultivate with but a tractor tiller would be to wide to fit between the rows and if u take the shovels of a cultivator u can use it only after u dics u use it the break the soil below where u disc to make it where water will raise to the plants when its dry and will go done when its raining so it wont flood the plants and when u do this the cultivator would be call a chisle plow
