troubleshooting charging system
/ troubleshooting charging system
Continuing saga.. I tested both diodes, they appear to be OK. I hear a relay click when the switch is ON. I tested AC voltage from alternator at the regulator/rectifier. It's same as at the alternator, 20v-50v. While running I measured about 25A AC current. Fuses and diodes appear to be OK, but I'm not getting >12v DC when running. I checked various point along the path and it looks OK. I really need to be able to plug the AC from the alternator into the rectifier and then measure the rectifiers DC out. To do that I'll need to splice in some wires so I can take the measurements. It's all one 6 wire connector. My best guess now is either 1) alternator is delivering good voltage, but not enough current or 2) the rectifier is not delivery sufficient DC voltage/current.
/ troubleshooting charging system #22
Rectifiers usual mode of failure is 'open'. in rare instances I have seen 'shorts'.. I have yet to see 'variable resistive' failures that deliver lower dc voltage from the rectified ac voltage.
Keep looking... You have ac source.. and no dc output...
How did you test the diodes? OOC?
Soundguy
Re: diodes. I put a multimeter (ohms) across the 2 connectors. In one direction there is 10 ohms resistence (closed), in the other infinite (open). I also tested dc volts along the path to see that voltage was getting "past" the diodes. I'm pretty sure they are OK. In diode controls a relay, and that relay "clicks" with the switch on, therefore the diode must be working. I think it's either alternator or rectifier at this pt. If I can "splice into the rectifier connector" I can measure the dc output. That would be the next clue. After that it would have to be some kinda of current flow issue.
/ troubleshooting charging system #24
Typical rectifiers use 4 or more diodes which are wired in as a bridge rectifier. Many have one or two more diodes as reverse current limiters so the battery doesn't discharge back through the rectifier/alternator to ground. These could be the diodes you're reading, which appear to read good.
As for the regulator, most if not all solid state regulators utilize a zener diode & resistor to produce the reference voltage drop and in many cases an SCR to control current flow to the battery. There will be associated cap's, transistors and resisters to control these devces. And unfortunately they are generally sealed in epoxy makeing them unserviceable.
I doubt that low current flow from your alt is your problem. An alternator's produced current is dependant upon load. Since your not measureing any DC voltage output at the battery, theres no load applied....
I find it unusual that the rectifier isn't integral to the alternator as this has been the standard for years. There will have to be a minimum of 4 to 6 wires between the alt the reg/rect. Three leads for the stators AC delta wireing output. 1 or 2 Wires for the field input and at least one wire for a common neutral. Since you are getting AC voltage out then it's safe to assume that the 12vDC field voltage is getting from the reg/rect alternator hense the connection between the alt & reg/rect is good.
The reg/rect module will need at least two or three additional leads from the tractor. A 12vdc battery/power lead, frame/system ground and if you have an idiot lamp, a lead for it also. Thats 6 to 10 leads to the reg/rect.
Barring a blown fuse, or loose ground, it still sounds like a defective reg/rect. /forums/images/graemlins/grin.gif
Good Luck
Volfandt
Thanks again for all the replies. Another update. There are 6 leads going into/out-of the rectifier/regulator. 2 lines in from alternator. 1 out to battery. 1 out to a safety relay that is diode protected to ensure current does not flow in reverse to reg/rect, 1 gnd, and 1 to a discharge light which indicates charging system failure. I made 6 test leads - connectors on both ends with exposed wire in the middle. I took measurements. In summary it looks NORMAL. Under load there is 15v AC across those alternator leads. Again, this is while plugged into the reg/rect and under load. Unplugged from rec/rect, there is 20-50v AC. The discharge circuit seems fine - nothing there to really care about anyway. With the switch ON, the rect/reg closes that circuit and the light comes on. Once running, it goes off. There is "battery voltage" on the lead to the battery, and with the switch on, there is "battery voltage" to the safety relay (indicating the relay is closed as it should be). I have a Harbor Freight multitester with the clamp on current loop. There is about 20-23 amps in the AC circuit to the rect/reg and (but not sure this multitest measures DC current) about 9-10 amps in the lead out to the battery.
All in all -- it SEEMS TO BE WORKING NOW! I see a slight voltage increase on that lead to the battery when the engine is running, about 12.5 to 13.5 volts. With engine off and key off, the battery voltage is just under 12v (I put it on the charger a night ago). But I do detect a slight increase in voltage (at the rect/reg) now that would seem to suggest I'm getting charging current.
It was pretty dusty in there.. the rect/reg was plugged full of dirt. I took the airhose to the whole area and cleaned it out. Also, I've disconnected and reconnected just about all the diodes, relays, connectors, etc that I can find (in hopes of clearing up any bad connections).
I did notice, this eve, with the switch ON, and engine not running, a relay clicking.. as if it was not making good contact. My guess, it's the saftety relay. So I pulled those connectors off and plugged then in/out several times. It's not clicking anymore. Perhaps that is the culprit. But I'm skeptical. I've left her "open" for now.. I'll take a few more readings when it's light out again.
/ troubleshooting charging system #26
</font><font color="blue" class="small">( I find it unusual that the rectifier isn't integral to the alternator as this has been the standard for years. There will have to be a minimum of 4 to 6 wires between the alt the reg/rect. Three leads for the stators AC delta wireing output. 1 or 2 Wires for the field )</font>
I've seen quite a few (strange and low tech ) alt's with permanent fields.. therefore no field control.. and output was very crudely regulated.. some yanmar dynamo are like this..
Soundguy
/ troubleshooting charging system #27
Sounds like you solved your problems,.. and it was a case of bad / dirty contacts..
Soundguy
/ troubleshooting charging system #28
In looking at the WSM for my BX23, it seems that the Dynamo not only has a permanent magnet field but that the rectifier is built into the outboard regulator too!
Looks like my 2004 BX23 is still using a non std & "crude" type of charging system /forums/images/graemlins/grin.gif
Theres two leads from the dynamo to the reg/rect and counting those two, 6 leads out of the reg/rect.
As long as it works /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
Glad the problem is fixed.
Volfandt
I'm doubtful. I took some more measurements this eve. I do have 13+ volts on the output side of the reg/rect. But at the battery term, that voltage is 11. According to the schematic that lead goes to a fuse, then the starter, than the pos. terminal of the battery. How can 13v at one point diminish to 11v at another? With the switch OFF, there is 11v at the battery and at the reg/rect. Connectivity is therefore good. Hmm, but I just measured the Vs across the battery pos and neg terminal. I suppose I should have measured from battery pos to frame ground as that would be the same reference grn as the reg/rect. Another test to do..
/ troubleshooting charging system #30
Now that is strange /forums/images/graemlins/confused.gif
You should physically trace the battery to starter to reg/rect cable(s) out. At this point I would look for a skinned spot where it's grounding out or a spot where the cable is cut down to where just a few strands are makeing connection. There may be something spliced in that shouldn't be.
According to the schematic on my BX23, the chargeing output lead from the reg/rect goes a term on the starter solenoid and that is also where my battery pos term ties down. Yours sounds similar. Make sure you can't wiggle 'em around.
Check your meter also. Sometimes those range dials can give false readings if not in the proper range position.
Good luck
Volfandt
Strange indeed. My clamp-on HF meter only as 1v dc accuracy - no decimal accuracy, so I pulled out my 30 year old Radio Shack analog tester. I'm in a range where the reading is about middle of the meter. Battery was 11v, rect/reg was 13v. When I switch to AC volts there is AC on the line. Is this normal? Even though it's suppose to be a DC circuit. Frustrating.
I put the covers all back on last eve. The rect/reg is under the steering column on the RH side. I still want to take a measurement from the pos term of the batter to the frame ground.
/ troubleshooting charging system #32
</font><font color="blue" class="small">( Looks like my 2004 BX23 is still using a non std & "crude" type of charging system )</font>
Crude may have been a hard term.. perhaps.. 'less sophisticated' is a better term.
I much prefer variable field control regulation, as well as over current control.
</font><font color="blue" class="small">( but that the rectifier is built into the outboard regulator too!
)</font>
I've seen that on grey market japanese units.
Soundguy
/ troubleshooting charging system #33
</font><font color="blue" class="small">( How can 13v at one point diminish to 11v at another? )</font>
Voltage drop.. either a restive contact, restive short.. or resistance due to wire gauge restriction.. like a pinched wire barely making contact.
Soundguy
/ troubleshooting charging system #34
</font><font color="blue" class="small">( Battery was 11v, rect/reg was 13v. When I switch to AC volts there is AC on the line. Is this normal? Even though it's suppose to be a DC circuit. Frustrating )</font>
Makes perfect sense. the charge out line has 13v on it. that battery only has 11v.. that means there is a break in the wire... The 'ac' you are reading onthe 13v line is probably just 'choppy' dc. If you have ever seen unfiltered half or even full wave dc on a scope.. you will notice that it is just the positive portion of a waveform... some meters read that 0 to + pulse as ac, when normally it would be a neg to pos swing, passing neutral. This is the same reason why most cheap vom's aren't real usefull for measuring dc generator output at the armature of an old gen, with no battery attached to filter the output.. the brush 'noise' confuses the meter.
I'd trace that line where it goes from 13v to 11v.. and that is where your problem is. ( Fuse? )
Soundguy
not much in that path.. reg/rect (13v) to fuse (although that parallels off to the switch also) to starter to battery pos term. I should be able to measure Vs at that fuse, and starter fairly easily. Course I say that sitting at my desk. Seems I find a different story once I pop the covers..
But what is confusing.. is that circuit works both ways. With the engine off, it's still "live". The battery itself drives 11v to that reg/rect. That's why a short, etc seems unlikely.
At that parallel off to the switch there is a whole other set of circuitry. When running, that activates a relay, and presents the voltage to another lead on the reg/rect. I'd probably have to copy this schematic and post it to make any sense. And I suppose there a other points of failure also, as presumably this is only the "charging schematic" and other electrical circuits could have an impact.
still a big mystery..
battery was dead again, so I put it on the charger, and measured current to the battery while on the charger.. started at about 9A and slowly went to 2A.. just as a charger is suppose to work.
So I start the engine and measure the current on the pos. terminal wire. It varies w/ engine rpm, from about 4A to 10A. If I unplug the alternator, that current goes to 0A. Makes sense right? Alternator running.. current flowing. Alternator off, no current.
Next I put test leads into the alternator path and measured voltge. This is AC out. When the alternator is in the circuit there is about 15V AC across the 2 alternator leads. When the alternator is OUT of the circuit there is up to 50V at high rpm. Still kinda makes sense to me.
The only bizarre scenario I an dream up is the battery is delivering current to the alternator!! A reverse of what should happen! That would explain the current readings. But it seems crazy. Or maybe I just have a bad battery?
/ troubleshooting charging system #37
It appears that something is draining your battery down. I don't recall if I explained a simple test procedure in an earlier reply so I'll repeat it if I did.
Charge the battery back up and reinstall it into the tractor if you removed it to charge. Connect the negative (neg) battery lead up but not the positive(pos) lead.
Get a 1056 or 1156 auto lamp and solder a lead to the lead tip and another to the brass/copper base. Wrap one of these leads around the pos battery term and use a pr of vise grips to hold it there. Wrap the other lead around the tractors pos battery cable clamp. Basically you have series'd in the lamp between the battery & the tractor.
With the switch off the lamp should NOT glow. A faint to bright glow indicates that something in the tractors electrical circuit is grounded. To isolate pull fuses one at a time and/or start disconnecting device connectors one at a time. When the lamp goes out you've found the problem.
Those reverse current diodes are generally the 1st to suspect but I've seen oil pressure switches do it also. Anything that had battery voltage sitting on one side with the key off can be suspect.
If you have no glowing lamp, turn the ign switch on to verify that it will glow.
If the lamp test good and it doesn't glow then hook the pos battery lead back up and series in the lamp to teh neg lead. If no glow then the system isn;t pulling enough amps to pull the battery down overnight.
You can use an ammeter set to milli-amps in the same manner but chargeing circuit will always draw a very slight current draw and this can be misleading.
Good luck
Volfandt
Sounds easy enough to test.. but the drain would be pretty small. When I put a good charge on the battery it will last several weeks.. or probably 50+ starts. I may actually tap into the pos. term at the starter.. would prolly do it good to disconnect, polish, and reconnect. It's a short run of wire.. 2 ft maybe.
/ troubleshooting charging system #39
</font><font color="blue" class="small">( The only bizarre scenario I an dream up is the battery is delivering current to the alternator!! A reverse of what should happen! That would explain the current readings. But it seems crazy. Or maybe I just have a bad battery? )</font>
I'd go with bad battery.. or short. It was a good guess.. but you are a little rusty on current theory. First.. if you had a vom, you should know which direction current was flowing.. next.. current flows from the source that is a higher voltage potential to a location of lower voltage potential. in other words.. your 14v alternator 'sends' current' to your 12v battery... Current will not travel from an area of low potential to an area of high potential.. that's an oversimplified explanation.. but pretty much holds water.
2 tests.. first.. remove battery terminals from battery.. and attach vom with test clips.. set to voltage.. check the meter... remove clips and check battery every time you walk by.. let battery set same length of time that it would take to go dead int he tractor. if the battery is internally discharging.. it will do it and you can measure that as a voltage drop... if it is the battery.. replace it.
next ...Get a test lamp or low wattage bulb.. remove your neg battery post and gator clip that lamp inline with post and terminal. if the lamp lights a bit.. then you have current flow.. and thus a short. Now.. start at the alternator and start disconnecting wires one by one working back toward the dash ./ battery.. when you finally pull a wire that make sthe lamp go out.. that circuit is the short..
Soundguy
/ troubleshooting charging system #40
Soundguy is right. I troubleshot a car system years years ago by using a light bulb in series with the battery, and found a bad relay causing a current drain. I would not have ever suspected this part as the culprit. If there is no current drain, battery is bad.
Polaris Ranger 800 4x4 (A64047)
Polaris Ranger 800...
BUNDLE OF MISC SIZE USED TIN UP TO 26' LONG (A62131)
BUNDLE OF MISC...
1948 Willys CJ2A Jeep (A61166)
1948 Willys CJ2A...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
1660 (A59213)
1660 (A59213)
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
