Troubleshoot 4310 Work Lights, PLEASE
   / Troubleshoot 4310 Work Lights, PLEASE #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Need your help . . . my work lights and beacon light attached to the top of my Curtis Cab all of a sudden stopped working. I replaced the work light fuse, but that doesn't seem to be the problem. I was out snow blowing one evening and they just quit on me. Can't see any wiring issues . . . is there something I'm missing, would appreciate any trouble shooting ideas.
Photos show my switch setup inside the cab, and the outside of my cab.
FredSG
   / Troubleshoot 4310 Work Lights, PLEASE #2
Use a volt meter and check where you have, and do not have, 12v.
One switch (knob) appears to have had some over-heating problems by the dark colors... do you have 12v to that switch, and out of it?
Also, fine a 12v hot wire, and use a jumper wire to feed(supply) your lights to check if they are in working order.
The black knob is the on off switch for the heater. That's working fine. The other two switches are for the beacon light and the work lights. These lights are not working as mentioned in my OP.
Beenthere,
Thanks, I'll have to test out my wiring and system as you suggested. Thanks for your help and for responding.
FredSG
   / Troubleshoot 4310 Work Lights, PLEASE #6
If it's just those two lights/systems, nothing else, then it has to be a common fault. A point where only those two circuits/wires connect to the power source together.
I would suspect a common connection, even a crimp. Vibration, over time, will loosen/break those connections. Gently wiggling/pulling on those connections may reveal the culprit.
Wagtail,
Thanks, will do, have to wait until latest snow storm passes, expecting up to 17" next few days. Appreciate all replies and suggestions.
FredSG
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
2006 KOMATSU PC50MR-2 EXCAVATOR (A52707)
2006 KOMATSU...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
