Rear Finish Mower Trouble with King Kutter Finish Mower
/ Trouble with King Kutter Finish Mower #1
Fishguy
Northeastern NC (flatland)
NH TC30 HST
I have a 6' king kutter, rear discharge mower that I am suddenly having problems with. All the trimmings are thrown to the left side of the mower when cutting. I started having problems with the grass being cut on the left side not being cut all the way. It started looking as if the blades were worn so I replaced all three. That did not fix the problem. I then thought that maybe something with the air flow underneath so I scraped all the old clippings off the bottom. Still didn't help. All the wheels are adjusted to the same height, the tires are solid so no low air and the bearings on the wheels are good.
Any ideas???
Thanks in advance,
Steve
/ Trouble with King Kutter Finish Mower #2
When you replaced the blades did you replace them with actual OEM blades? Was any of the old blades bent? Are your blades off-set with each other, or they all in line with each other? Do the bearings in the spindles still feel tight? Just some helpful things to look at.
/ Trouble with King Kutter Finish Mower #3
First remove your belt and make sure all the blade spindles spin free. When you reinstall your belt check the tension. It seems like your belt is slipping.
Bill
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2009 GMC SIERRA 2500HD (A67714)
2009 GMC SIERRA...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
