Triumph & Sidecar
/ Triumph & Sidecar
Bird:
If you look through the pictures, you will note that it has it's own brake. Actually, it's a Performance Machine twin piston caliper gripping a stainless, drilled rotor. It's set up just like a tractor, split brakes with the sidecar brake pedal right next to the bike's brake pedal. Though not interlocked, your boot will cover them both or individually if you prefer. I tend to rock my foot when applying the brakes to keep the inertia of the sidecar in balance with the bike. The sidecar is like a pendulum. When you accelerate the bike, the sidecar pulls to the right. When decelerating or braking without using the sidecar brake, it pushes to the left. There is a definite learning curve involved with a sidecar as the sidecar forever alters the geometry of the bike.
When you first operate a sidecar, you must try to forget anything you learned about a two wheel motorcycle. It's hard to adjust to and at first a little scary especially entering a curve at speed. The outfit really tends to over steer until you learn how to compensate. I almost put it in the ditch a couple of times last year. I'm more comfortable with it now. Actually, I believe I'd feel somewhat alien on 2 wheels again.
There are a couple of advantages to having a sidecar, especially one with high performance brakes. You can literally stop on a dime even on wet roads. Loose gravel in a turn poses no hazard for an outfit whereas loose gravel is a trip to the ER on a two wheeler and you never have to put your feet down at a stoplight. /forums/images/graemlins/grin.gif
If my outfit was a beater, I'd ride it all year. With off road tires, it's manners in the snow and mud would equal an off road bike or a quad. There is actually a sidecar outfit on the market that has both rear wheels driven. It's a Ural. Great bike for the woods.
You can order any sidecar without brakes, but the brakes make it safer. The key to braking is modulating the sidecar brake to be in harmony with the bike brake(s). Some bike like the Goldwing and the big Harley's have the sidecar brake plumbed right into the brake system of the bike so when you apply the bikes brakes, the sidecar brakes are applied proportionally.
With fuel prices going through the roof (that's another thread), efficient transportation with storage capacity becomes more viable. While I built mine for show and not utility, 40 mpg is nice and I can haul a load of groceries too.
With the sidecar off, the bike will run a respectable mid 13 second quarter mile. Even with the sidecar, it's no slouch. Of course I massaged the motor a little. I have to tinker, it's my nature. /forums/images/graemlins/grin.gif
The new Triumph is actually designed to be an English Police bike. Everything about the engine and drivetrain is very robust and the frame is a full double cradle with a rectangular swing arm. It's well designed to take the stresses a sidecar imposes.
/ Triumph & Sidecar #22
</font><font color="blue" class="small">( <font color="blue"> You need to get back to your youth. I prescribe a new Triumph. </font> )</font>
Ah!!!! What can I say. I started my mororized life on a Triumph Tiger Cub and graduated on up. Man, I am so jealous. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif That is one beautiful machine.
I'm just afraid I'll never be able to join you in your passion. One of the few times my wife ever put her foot down was when I started looking at bikes when I retired. When that lady categorically says "NO", you'd better listen. Life has a habit of going down the tubes if you don't. She told me that I didn't bounce nearly as high as I did when I was younger and that I didn't have nearly enough life insurance. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif Maybe I can talk her into it if I just park it and stare at it every now and then.
/ Triumph & Sidecar #23
That is one beautiful machine. Down here its getting up into the mid to high 80's today. No wind, no clouds... just a beautiful day to ride.
She is stunning. Thanks for sharing!
/ Triumph & Sidecar
Frank:
Sidecars are a lot safer. You travel much slower, gravel in corners isn't a problem....they are just the thing for us older generation. Besides, they are a Chic Magnet like we need that. /forums/images/graemlins/grin.gif
If I had a chic in there, well................ /forums/images/graemlins/smile.gif
/ Triumph & Sidecar
tjkadar:
I'm jealous but the good weather will be here shortly.
I think my M9 is beautiful too, but for a different reason. At least my Triumph and tub is paid for. /forums/images/graemlins/grin.gif
/ Triumph & Sidecar #26
</font><font color="blue" class="small">( I'm jealous but the good weather will be here shortly )</font>
I'm not sure I'd call it "good" weather, but my outdoor thermometer in the shade is showing 85 right now. Your heating bill is going down and my cooling bill is going up. /forums/images/graemlins/frown.gif
/ Triumph & Sidecar
Bird:
Last year Amy put over 90K into the old barn (house). I guess we are staying put for a while. We have never needed central air in the summer, the whole house is shaded by maples and ash trees (which I religiously inoculate with pesticide annually...we have about the only ash trees left around here because of the Asian Ash Borer Beetle). Amy had wet cellulose insulation blown into the space between the uprights and the later placed new drywall and our house is actually made from on site hand milled planks and lumber pinned together with wood pins. Our outer wall to drywall space is around 10" so that much insulation should help keep it even more moderate. Our heat bill this winter cosisited of 4 skids of wood pellets for the pellet stove and Amy had it at 72 degrees all the time. I burned about 200 gallons of LP to heat the shop. That's it. Next season the shop will be heated by corn.
I have to keep my bike and sidecar warm and toasty in the winter!!
/ Triumph & Sidecar #28
Beautiful bike, I remember riding them when they were new...
Buddy had one when we were in college, couldn't get it to start in the dead of winter, so we hauled it up the elevator to the top floor to our dorm room to work on it. Found a short in the points and fired it up at 2 am just to see if it ran - woke the whole floor up!
/ Triumph & Sidecar #29
I'm a big fan of your M9 too. I could get used to a cab very easily. Plus, that extra power will come in nice when I'm trying refurbish my pastures.
I keep telling my wife I need a cab so my dog can ride with me on the tractor safely. I might convince her one day...
I would love to have another motorcycle, but riding on the road terrifies me. For about ten years I only rode motorcycles. I didn't even own a car. I finally got onto the race track with my bike and I haven't been able to put a bike on the road again.
People down here are very, very poor drivers. /forums/images/graemlins/frown.gif
/ Triumph & Sidecar #30
Just a beautiful bike Daryl,
So THAT'S what you've been telling me about. I cut my teeth on triumphs and love the lines. Back then, they were the only other bikes allowed to ride along with the "Angels out in my part of town.
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
