Tricyle Backhoe Dolly
/ Tricyle Backhoe Dolly #13
That also is a nice looking back hoe rack. The lawn vac is pretty neat, too. Is that just a regualr leaf blower you have attached to the trailer front? Are you simply using flexable duct from the mower deck to the blower intake?
Yours was probably the dolley I based mine on. I looked through TBN to find the picts for the post and couldn't.
Mine attaches the same way as yours.
A single swiveling wheel may seem less moveable, but because you don't get into the situation where two wheels are pointing in different directions, it actually makes it pretty easy to move. The weight makes all the difference.
Also, big solid wheels help moving a lot, and having only one front wheel makes it easier to steer. Mine are solid metal wheels.
I was always very impressed with the workmanship of your dolley.
/ Tricyle Backhoe Dolly #17
mrcaptainbob
Thanks for the complement. Yes the vacuum is a just a blower someone gave me. I rotated the housing and made a fiberglass adapter to go from blower to trailer. This reduces the leaves to about 8:1 or 10:1. Using gator blades on the mower helps. I have never clogged this setup yet and I have driven into 3' piles of leaves mixed with morning glory vines with out a problem. I'm going to post more pictures as practice. Those in the other post were errers on my part. leaf leaf2b
I also made the sulky for the mower. I only use it when I use a trailer of some type. leaf3
Still tweeking the set up but I will never be without something similar ever again.
/ Tricyle Backhoe Dolly #18
boustany
The wheels I used on the dolley can either swivel or be locked in any position. When they all swivel it helps getting everything into the corner of the garage. I'd like to say I designed it this way but I can't. Those wheels came with some of the scrap steel I bought. I try to design around what I have available.(cheap and broke) As long as what I make works I'm happy. If someone can use my ideas I'm even happier.
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
