Trenching
/ Trenching #11
Mike,
Is that for the big four wheel drive one or the little ones?
/ Trenching
I live in South Carolina. We have the type of grass here that doesn't go dorment in the Fall and Winter. People are still watering now and I'm not sure when they stop if at all. This is kinda a spring project I'm gearing up for so I have time to figure all that out.
Jeff
/ Trenching #13
It's a walk behind - manhandle - 2 wheel drive at rear - and 1 small wheel up front as a guide wheel --- not sure if by "manhandle" I mean it takes a "real" man to handle it ---- or if I mean (which is the case with me) working it for a day you really know you've been manhandled at dusk.
It did the job though - I trenched over 200' ---24" deep for new water line from the well to 2 houses. When I rented it I warned 'em I had a lot of rock - they said it should deal with the rock Ok and there'd be no charge for damage if it didn't. Good thing - I broke 1 tooth off and severely bent 2 others. They lost money on that deal.
mike
/ Trenching #14
Yea that's the small one Mike. The one's for $160 are four wheel and you drive them with a joystick. There isn't any manual effort to it.
/ Trenching #15
oh - sorry - I thought you meant the small ones were that much ---- I never priced the big ones - - but the older I get the more power and ease I need --- so the next time...
/ Trenching #16
Yep me too Mike that's why I keep buying more equipment. /w3tcompact/icons/smile.gif
/ Trenching #17
Several years ago, I got the same deal and blew up the transmission on a big pine root. (Blew up as in pieces scattering so far I couldn't find them all.)/w3tcompact/icons/blush.gif Being a regular at the rental place, I felt sheepish taking it back. Imagine my surprise when the counterman called the mechanic out and they were both overjoyed. Seems they'd been through 3 brands of engines, and when the transmission went they figured they'd finally found an engine that would stand up. I still rent from them, and they're still in business, so I guess learning from your mistakes is part of getting better at things.
I came up with a saying that has stood the test of time if you're looking at some tough trenching: "Don't get the biggest one you can walk behind, get the smallest one you can ride on."
Good luck, and be careful.
The Sub Dude
I'm gonna live forever....So far, so good....
/ Trenching #18
yep, loads of fun to "adjust" the direction of those three wheel units.
The one day rental cost me about $100 with the trailer.
Net result is ~165' 22" trench.
Not exactly the straightest trench, but it was cheap. /w3tcompact/icons/smile.gif
Fred
/ Trenching #19
Last year I rented a 3pt. chain-type trencher that I put on the 3pt of my JD 4300. It worked great! It was very similar to the Bobcat trencher (may have been Bobcat equipment, although I don't remember for sure). It would adjust up to a depth of about 4 ft. A hyd. top link adjusted the depth, and the 3pt control adjusted the height of the augers that pushed the dirt from the trench to the side. Easy to control and quick to move around.
/ Trenching
Yeah, and then I could point to this expensive tractor and say "See honey, it was absolutely necessary!"
Jeff
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
