Tree Trimmer Build
/ Tree Trimmer Build #11
Oh yea, I do not have anywhere near what you have, just about 100yds of drive to trim, but have tried the "chainsaw on a stick" and it gets old and HEAVY real fast.
Now if I could put the saw on a stick on my FEL.........
That blade says 8000 max rpm. There is also a limit of 6gpm in the case return connector I bought, so probably not going to get anywhere close to max speed.
At 6 miles to trim, I can see it.. Around here, they use a bush-hog-on-a-stick (boom).. makes quit the mess, but is very fast :)
I have this:
Skid Steer Brush Cutter Bushmaster - YouTube
Does a great job but, it's hard to trim the sides of trails and roads with. It has done a fantastic job at clearing some seriously overgrown areas and for cutting new trails. The excavator model would do what I want, but then I'd have to buy an excavator....
/ Tree Trimmer Build #15
I have this:
Me want!
I have soo much overgrowth to clear I'm looking for ways like that to do it... wonder if I can adapt it to my FEL?
Here is their website. Rotary Cutters
I have the SL601. As long as you have a quick attach on your FEL and depending on your lift capacity, you could probably get one that works. The hydraulic flow might be a problem, but a PTO mounted pump would be a possible solution. The Tazmanian model only requires 10gpm and is lighter. I'm not familiar with the mini-skidsteer mounting plates though. Not sure if it'll work on a standard quick attach or if you need an adapter.
/ Tree Trimmer Build #17
I have a Ford 3400 with 730 FEL. No quick attach as of yet, but it does have a 13.5gpm
/2100 psi front mounted pump.
Thanks..
/ Tree Trimmer Build #18
I like it , nice simple layout . Good work . When you build it yourself you don't worry about liability or lawyers , you just make it work .
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
Sakai SV505 (A60462)
