Tree planting
/ Tree planting #1
m1greg
S.E. Michigan
Kioti CK20H & Deere 455
Planted a tree to commemorate my daughter's Christening and had no problem getting the hole 2 1/2 times the diameter of the root ball! ( Hey I don't have a backhoe! ) /forums/images/graemlins/laugh.gif
/ Tree planting #2
m1greg,
On your profile you say you have a Deere this pic shows an orange tractor ,what is it? /forums/images/graemlins/confused.gif
/ Tree planting #3
KIOTI, of course. /forums/images/graemlins/grin.gif Gerard
/ Tree planting #4
It could just be an illusion, but it appears that the tree is planted 4" or so below the natural ground level. If you are going to backfill up to the ground level, your tree is going to suffer from being planted to low.
As the saying goes, "Plant it low and it won't grow; plant it high and it won’t die."
/ Tree planting #5
</font><font color="blue" class="small">( m1greg,
On your profile you say you have a Deere this pic shows an orange tractor ,what is it? /forums/images/graemlins/confused.gif )</font>
Kioti buckets are black, Kubota orange.
Nice little tree. /forums/images/graemlins/smile.gif
RedDog
/ Tree planting
</font><font color="blue" class="small">( It could just be an illusion, but it appears that the tree is planted 4" or so below the natural ground level. If you are going to backfill up to the ground level, your tree is going to suffer from being planted to low.
As the saying goes, "Plant it low and it won't grow; plant it high and it won’t die." )</font>
The top of the root ball is aprox 8" below ground level on the high side of the slope. I plan on adding a couple of inches of mulch to it this weekend. Is that still too shallow?
M1Greg
/ Tree planting
I was just trying to see if anyone was awake /forums/images/graemlins/wink.gif
It's a Kioti ck20h I've updated my profile.
/ Tree planting #8
Gatorboy is right, tree is too deep if you were going to restore the original grade
If you dont and your soil is clay you might drown your tree and your 2in of mulch might float away.
/ Tree planting #9
<font color="blue"> The top of the root ball is aprox 8" below ground level on the high side of the slope. </font>
I would set the top of the root ball at the same level as the high side, which will then be slightly above on the low side after you backfill. You can always add mulch, etc. to the lowside -- as you have it now, you are going to be burying the top of the rootball, which is not what you want to do.
/ Tree planting #10
I was thinking the same thing. Bad for the crown if any more dirt goes in there. It's going to settle down some as well even as it is. John
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
Unused 2025 USA Attachments Quick Coupler Excavator Attachment (A66734)
Unused 2025 USA...
2016 CATERPILLAR 289D SKID STEER (A65056)
2016 CATERPILLAR...
2003 Johnson 60 hp 4-stroke Outboard Boat Motor (A66738)
2003 Johnson 60 hp...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
