Treated or regular lumber?
/ Treated or regular lumber? #11
TBDonnelly said:
In my area I've seen many basement where steel studs were used.
Don
Bingo! Do like the commercial builders do and use metal studs, or a smaller metal furring channel fastened directly to the block wall.
Also, if you have a concern about moisture, address that rather than building to accomodate the water. You would be much better off sealing the space from water [liquid or vapor] than planning for wet building materials.
/ Treated or regular lumber? #12
Whether someone has moisture problems or not, direct contact with concrete requires PT wood.
That's always been my understanding too... I've decided I'll just go with the treated & not worry about it.
/ Treated or regular lumber? #14
From what I remember around here, vapor barrier is required between masonry and wood no matter what type of wood.
Steve
2020 VOLVO VNL760 TANDEM AXLE SLEEPER (A59906)
2020 VOLVO VNL760...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
