Mar 14, 2009 / Traveling Speeds #1 C ChrisR Bronze Member Joined Jul 19, 2001 Messages 66 Location Henley Brook, Westen Australia Tractor Kubota L35 Hi I am going to check my L35's speed against the table that comes in the manual. It lists the supposed speed against each gear. i.e. gear 1 = 1.4 km etc. The problem is, that it says to do this at rated engine rpm, well I can't find what that should be. Any ideas???? Chris
Mar 14, 2009 / Traveling Speeds #2 P pdowling1 Silver Member Joined Jul 24, 2006 Messages 194 Location Falling Waters,WV Tractor Kubota BX2200 All it has, WOT, pedal to the metal.....
Mar 14, 2009 / Traveling Speeds #3 W Willl Elite Member Joined Jul 22, 2006 Messages 4,408 Location Northwest, WA ChrisR said: I am going to check my L35's speed against the table that comes in the manual. Click to expand... Why ?
Mar 14, 2009 / Traveling Speeds #4 G greenmule Platinum Member Joined Jan 15, 2009 Messages 966 You planning on entering it in a race or something or what?
Mar 14, 2009 / Traveling Speeds #5 Evil the Weasel Platinum Member Joined May 17, 2007 Messages 703 Location Central NY Tractor Kubota B2620 Trying to get out of a speeding ticket?
Mar 14, 2009 / Traveling Speeds Thread Starter #6 OP C ChrisR Bronze Member Joined Jul 19, 2001 Messages 66 Location Henley Brook, Westen Australia Tractor Kubota L35 Well The tractor seems to be running much slower than it used to, so to see whether this a figment of my imagination or a mechanical fault, I thought I'd check it. Seems fair enough!! Chris
Mar 15, 2009 / Traveling Speeds #7 M MarkV Super Member Joined Apr 7, 2000 Messages 5,698 Location Cedartown, Ga and N. Ga mountains Tractor 1998 Kubota B21, 2005 Kubota L39 I would say that "rated engine rpm", as Kubota would refer to it, would be PTO speed. MarkV
Mar 15, 2009 / Traveling Speeds #8 ericher69 Veteran Member Joined Aug 19, 2008 Messages 1,666 Location Ontario Canada Tractor 2008 Kubota b2920 As per my owners manual and spec sheet for the B2920 the "rated" engine speed is the maximum rpm that the engine is rated for in my case 2800rpm. Does this correlate to pto speed...depends on which pto mid or rear? Best way is to go online and check the spec sheet for your model. Hope that helps
