Traveling Speeds
/ Traveling Speeds #1
ChrisR
Henley Brook, Westen Australia
Kubota L35
Hi
I am going to check my L35's speed against the table that comes in the manual.
It lists the supposed speed against each gear. i.e. gear 1 = 1.4 km etc.
The problem is, that it says to do this at rated engine rpm, well I can't find what that should be.
Any ideas????
Chris
/ Traveling Speeds #4
You planning on entering it in a race or something or what?
/ Traveling Speeds
Well
The tractor seems to be running much slower than it used to, so to see whether this a figment of my imagination or a mechanical fault, I thought I'd check it.
Seems fair enough!!
Chris
/ Traveling Speeds #8
As per my owners manual and spec sheet for the B2920 the "rated" engine speed is the maximum rpm that the engine is rated for in my case 2800rpm.
Does this correlate to pto speed...depends on which pto mid or rear?
Best way is to go online and check the spec sheet for your model.
Hope that helps
