Trash burner, Ember arrestor
   / Trash burner, Ember arrestor #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Made from a 250 gal fuel oil storage tank. Both ends open so you can put in a lot of long brush. The spark arrestor has 3/8" diamond shaped holes. In the middle, a lower door opens down for ashes and an upper door opens out for smaller stuff.
Another photo
Another photo
And another
# 5 pic
#6 photo
Grate is plenty heavy so it won't blow away
Whoops, the photo. I use to post a lot here but I've changed to a Mac and the format is different RCH
Inside view
   / Trash burner, Ember arrestor #10
OK, that looks real good, but since we never see those fuel oil storage tanks in this part of the country, I was wondering about the thickness of the steel. Do you have to limit the size of the fire to keep the steel from getting too hot and warping? And with both ends having doors, why did you bother to cut a door in the side? Just curious.
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2803 (A50460)
2803 (A50460)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
