Transport box
/ Transport box #1
barn606
chester
zetor
Hello. Can I use a transport box to clean sheds out (the slurry/wetter/part sawdust at the front of sheds near feed fence.)
I use a JCB 3cx to load spreaders but it will not fit through the doorway I am considering using
Don't want to use a scraper as will pull it out onto a yard the environment agency would like me to keep clean. (Gravel /poor yard)
The ability to remove the front section a few times between cleaning whole shed would help a lot.
I understand that over time it will wear the blade but as they are relatively cheap and I could use it for a number of other little jobs that the JCB is a little overkill for.
Thoughts ?
Thanks
/ Transport box #2
What is a transport box?
What is in the shed?
/ Transport box
Cattle. Mainly youngstock 3-9 months
/ Transport box #4
Found some pictures: transport box on a tractor - Google Search
/ Transport box
Yep like the bottom ones. There's vids of them moving stone so muck should be ok right ? Or would it not be able to pick it up enough
No point if I have to go in the shed 40 times . Thinking I need the hydraulic arm to give a tilt
/ Transport box #6
I think it would work fine.
But it would work much better with a hydraulic top link. :thumbsup:
/ Transport box #7
BARN606 ~~ Where are you? England? Maryland?
2022 EZ-GO ELITE...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2008 New Holland T2420 (A62177)
2008 New Holland...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Unverferth Field Cultivator (A64127)
Unverferth Field...
1998 International 9400 (A64127)
1998 International...
