Transport box
/ Transport box #1
barn606
chester
zetor
Hello. Can I use a transport box to clean sheds out (the slurry/wetter/part sawdust at the front of sheds near feed fence.)
I use a JCB 3cx to load spreaders but it will not fit through the doorway I am considering using
Don't want to use a scraper as will pull it out onto a yard the environment agency would like me to keep clean. (Gravel /poor yard)
The ability to remove the front section a few times between cleaning whole shed would help a lot.
I understand that over time it will wear the blade but as they are relatively cheap and I could use it for a number of other little jobs that the JCB is a little overkill for.
Thoughts ?
Thanks
/ Transport box #2
What is a transport box?
What is in the shed?
/ Transport box
Cattle. Mainly youngstock 3-9 months
/ Transport box #4
Found some pictures: transport box on a tractor - Google Search
/ Transport box
Yep like the bottom ones. There's vids of them moving stone so muck should be ok right ? Or would it not be able to pick it up enough
No point if I have to go in the shed 40 times . Thinking I need the hydraulic arm to give a tilt
/ Transport box #6
I think it would work fine.
But it would work much better with a hydraulic top link. :thumbsup:
/ Transport box #7
BARN606 ~~ Where are you? England? Maryland?
Transfer tank (A61567)
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
KUBOTA KX71-3 EXCAVATOR (A65053)
KUBOTA KX71-3...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
