Tires Transmission
/ Transmission #1
38019
MF-35
I have a 1964 MF-35 with the Perkins Diesel engine.
My problemis the transmission shift lever is stuck in first gear.I can shift the hi-lo level no issue. I went to shift from first to second.The shift lever start to move then became stuck I can't budge it.
Any suggestions?
/ Transmission #2
Found this using the search engine for this site, hope it helps.
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them.
Good Luck,
/ Transmission
Thank you for the info. IT WORKED.
Sorry for the delay in replying as I have been away for a while.
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
