Transmission types for JD 40 series.
   / Transmission types for JD 40 series. #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I'm a bit confused by some of the sale ads for JD 20x40 series of tractors - 2040, 2240, 2440, 2640.
I've seen them advertised as collar shift (sliding gear), synchro shift, hi-lo and reverserer.
My confusion comes about when I see a tractor advertised as having a hi-lo transmission and the picture doesn't have the left-hand lever on the console with the rabbit and turtle. However, there's a pic of the double shift levers on the floor with the 2-range shift lever on the left and the 4-speed shift lever on the right.
Are they trying to convince folk's that the 2-range is the hi-lo? If that's the case, then what's with the rabbit and turtle on the left hand lever on the console?
Thanks in advance.
AKfish
   / Transmission types for JD 40 series. #2
Aren't the rabbit & turtle universal symbols for engine speed/throttle?
Yep... (maybe the rabbit and turtle is on the right side)? :eek:
What's the 2nd lever on the console for - besides the reverser?
Isn't that where the hi-lo shift is?
AKfish
   / Transmission types for JD 40 series. #4
Thanks in advance.
AKfish
JD did make 40 series with 2 sticks and a high low on the dash. I drove a 2940 that was set up that way. The rabbit and the turtle would be the high and low.
   / Transmission types for JD 40 series. #5
I think those that advertise their 8spds as Hi-Lo just do not know any better.
If you have Rabbit-Turtle on the left, that is the Hi-Lo. Back then Rabbit-Turtle was not used for the throttle as it is now.
I do not think any were syncros.
Only collar shift with or without either Hi-Lo or Reverser, but not both.
   / Transmission types for JD 40 series. #6
My 755 uses the rabbit and turtle for both the throttle and the Hi-Lo range selector.
   / Transmission types for JD 40 series. #7
What year is your 755? My 1974 JD 2030 only uses Rabbit Turtle for the Hi-Lo.
No label for the throttle.
Is the hi-lo a "wet" or hydraulic shift? Or is it a "dry" clutch shift?
Thanks.
AKfish
   / Transmission types for JD 40 series. #9
Purchased new in 1993. s/n shows 1992 model.
   / Transmission types for JD 40 series. #10
Tractors with sticks on the floor have hi-lo in left of steering wheel and SG cabs have a small lever to the left of the sticks on the console if i remember right . Hi lo is hydraulic i believe .
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
40' CONTAINER (A51244)
CFG Industrial SAII100 (A50123)
CFG Industrial...
toro turf sweeper (A50324)
toro turf sweeper...
