Transmission Troubles
/ Transmission Troubles #1
Swarfeater
Ford 1920
A while back I posted a problem about my 1910 ford. It (manual trans) had a severe drag in all gears as if it was pulling a 55 bottom plow, and even in neutral it would chug backwards with each piston firing. i got no answers to the problem but i believed it to be a synchro problem which everyone disagreed with. i finally got the tractor apart and sure enough, bad reverse/2nd synchros. In fact one of the 3 keys that apply pressure to the synchro lock out rings had sheared and tore the heck out of the reverse synchro ring which was then left partially engaged. One thing i did find out is that replacement parts such as these are virtually extinct, and only a world wide parts search found one of the few remaining sets left. The keys are long extinct, so 6 hours of machining and heattreating in the shop solved that problem. If anyone else comes up with the same problem, i wish the best of luck finding the parts.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
Single Cedar Glider (A65583)
Single Cedar...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
