Transmission sheared gears
   / Transmission sheared gears #1
gsdavis1
Cleveland, OHIO
John Deere 855
I just picked up a 1500 D with some sheared gears in the transmission. Does anyone know of any one looking to get rid of a used transmission? The tranny is all apart, I could maybe just replace the broken pieces, but the problem is that I did not take it apart...I got it that way...so re-assembly will be a challenge.
Also, is it possible to replace the current transmission with a power shift?
Greg in North East Ohio
pastor@southwestbaptist.org
   / Transmission sheared gears #2
You can try LMTC or Little Miami Tractor Co. He is about as good as it gets esp.for your area. Sound like a very unusual trans. problem I would see what he has to say.
Carey
   / Transmission sheared gears #3
"Posted by jerry on Monday, January 11, 2010:
I have a YM1500 minus an engine I would sell cheap.I'am located in Georgia.It has good transmission and rearend with great tires,wheels and sheetmetal.
Jerry"
You might check with this guy on SSB.
Thanks for the replies guys.
I left a message at Little Miami
Also...what is SSB?
Greg
   / Transmission sheared gears #5
SSB is a discussion forum much like this one. The link Norm posted will take you to where you can email the author (Jerry) of that post.
Also, will a transmission from a 1500 fit a 1500 D?
Greg
   / Transmission sheared gears #7
It might but the 4 wheel drive model has some different parts inside. You may want to go to Hoye's website and look at the diagrams in the catalog. There is a link to Hoye's website at the top of the page.
   / Transmission sheared gears #8
Greg
Most of the time you will be better off rebuilding your transmission, if you use a YM1500 transmission, the gears that you will have to change out may just be the gears that are bad in your old transmission, so you are no better off. You could buy a YM 1500D transmission, but that won't be cheap. I don't have a YM1500D transmission, but I may have parts to repair yours.
Danny
   / Transmission sheared gears #9
   / Transmission sheared gears #10
Do I believe you need 4wd. In Ohio NO. Just deepends on what you plan to do with it.I use to live just out of Cinn. The 1500 in Ga. is sounding better might want to check into that and see if it is still available.If you plan on doing it yourself may come out better doing a split or a motor swap. I can make Cinn. in 7hrs. driving easy just something to think about. You will also have alot of spare parts left over that may come in handy one day or sell them to someone who may need them. With all the VN. recons around the area the spare parts may be a hot commodity;)
Carey
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
