TRANSMISSION PROBLEM ON FX24D
/ TRANSMISSION PROBLEM ON FX24D #1
7428
WASHINGTON STATE
YANMAR FX24D AUTO SHIFT
I PUT A GOOD USED AUTO SHIFT TRANSMISSION IN MY FX24D ALONG WITH CLUTCH PILOT BUSHING PRESSURE PLATE ECT.
I DROVE THE TRACTOR ABOUT 40 FEET EVERYTHING SEEMED TO WORK FINE AND PARKED IT FOR ABOUT 10 MINUTES WITH THE ENGINE RUNNING BRAKE ON AND WHEN I WENT TO BACK UP THE TRACTOR WOULD NOT MOVE
I TRIED FORWARD AND STILL NOTHING
I FINALLY MADE IT BACK TO MY SHOP BY PUSHING IT
I CHECKED THE FLUID AND IT WAS FINE LEVEL OK
BUT NOTICED SOME SMALL AIR BUBBLES IN THE OIL AND WHEN LOOKING THROUGH THE DIPSTICK HOLE WHEN I PUT THE TRACTOR IN FORWARD OR REVERSE I NOTICED OIL WAS IT LOOKED LIKE SPRAYING INSIDE TO THE LEFT OF THE CENTER PLATE THIS MAY BE NORMAL BUT IAM NOT SURE
IAM GOING TO REPLACE THE O RING AT THE SUCTION TUBE IN CASE IT IS SUCKING AIR
THE LOADER AND THREE POINT WORK FINE
I ALSO CLEANED THE SUCTION SCREEN BEFORE I INSTALLED THE TRANSMISSION
IT WORKED GREAT UNTIL I STOPPED IT FOR ABOUT 10 MINUTES CAN ANYONE HELP ON THIS ISSUE MAYBE SOMEONE ELSE HAS HAD THIS PROBLEM
ANY HELP WOULD BE GREAT
THANKS
CW
/ TRANSMISSION PROBLEM ON FX24D #2
Does the PTO still work? Could you have knocked the HI/LO range selector out of gear?
YES SIR THE PTO AND THE LOADER WORK FINE
AND WHEN I PUSH IN THE CLUTCH THE PTO STOPS TURNING LIKE IT SHOULD
HOWEVER I JUST WENT OUT AND STARTED THE TRACTOR AGAIN AND LOOKED THROUGH THE DIP STICK HOLE AND NOTICED THAT WHEN I PUT THE TRACTOR IN FORWARD OR REVERSE THE OUTPUT SHAFT TO THE LEFT OF THE CENTER PLATE IS TURNING AND AGAIN WHEN I PUSH IN THE CLUTCH IT STOPS LIKE IT SHOULD UNLESS IT IS JUST FREEWHEELING
I THINK I WILL PULL THE SIDE COVER AND SEE IF I CAN TELL IF THE LEVER FOR THE THREE HIGH LOW SPEEDS IS ENGAUGING
YOU COULD BE RIGHT BUT I CAN FEEL AND HEAR THE HI/LOW THREE SPEED LEVER SHIFTING INSIDE AND BY WATCHING THE LINKAGE IT IS SHIFTING ALSO
ANY OTHER SUGGESTIONS??
THE GUY I BOUGHT THE TRANNY FROM IS A GREAT GUY SO I KNOW IF THE TRANNY HAS A PROBLEM HE WAS UNAWARE OF IT THANKS FOR THE REPLY
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
80003CFL (A61568)
80003CFL (A61568)
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
