Transmission Operation Yanmar 2310
   / Transmission Operation Yanmar 2310 #1
YANMAR2310
Hello, hope everyone had a better week than me. Does anyone know where I can fine info on how the transmission in my Yanmar 2310 works. It was having some delayed engagements and Wednesday it put it self on a engagement hold. Not sure if it is a clutch? The PTO also stopped working. If I install it in gear with the pto engaged without a load, the pto will turn slow. However the tractor will not move. ANy help would be great. Thanks
David
   / Transmission Operation Yanmar 2310 #2
David
Sounds like a clutch, main shaft or something in the drive mechanism. The main shaft transmits power from the clutch to the transmission and pto, neither of which are working. You should be able to troubleshoot with the shifter cover removed.
   / Transmission Operation Yanmar 2310 #3
Yanmar2310,
I agree with normde2001 that it sounds like your clutch. If it is the clutch in your YM2310 the parts are readily available from several sources and changing them out is not too difficult. I know because I changed out all of the clutch related components in my YM2310D this past winter.
With regard to your question about how the transmission in the YM2310 works you will find the answers you need in the service manual for a YM276. That is the US model equivalent of the YM2310. It has service and theory sections on all of the parts of the tractor including the transmission. I relied on the service section of this manual this past winter to help me change out the clutch in my tractor.
If you have any specific questions that you think I can help you with PM me and I'll try to answer them as best I can.
John
Thanks for the nfo.
Diesel Forklift (A51691)
Diesel Forklift...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2012 International 4300 Reefer Truck (A52748)
2012 International...
