Transmission noise in low range
   / Transmission noise in low range
Will operating tractor with what is making noise do damage to tractor , or should I find and fix problem.
   / Transmission noise in low range #12
If you found a piece of gear tooth when you drained the transmission oil then you have identified the problem and yes using it in low range with a broken tooth will do more damage.
You can use the old wooden broom handle trick to get a general location of where the sound is actually coming from.
   / Transmission noise in low range #13
I can't help you with yours, but my 3000 diesel makes no noise in low or high range. So you definitely got something going on. I would really try and find where that piece of tooth or metal came from.
Thanks to everyone who responded.I’m getting a lot of experience working on this tractor.lol
   / Transmission noise in low range #15
Well once you get it all straightened out I hope you enjoy it as much as I like my 3000.
I got one more fall agricultural fair to attend with it, then I will also be pulling off the lift cover to change my filter and put new gasket and o-rings as my rear remote valve is leaking at the base.
2009 PETERBILT 365 (A55745)
2009 PETERBILT 365...
2021 Chevrolet Tahoe SUV (A55758)
2021 Chevrolet...
CFG Industrial H15R (A53316)
CFG Industrial...
Pickup Instructions (A47477)
Pickup...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A55788)
2008 Ford F-550...
