Transmission noise in low range
   / Transmission noise in low range
Will operating tractor with what is making noise do damage to tractor , or should I find and fix problem.
   / Transmission noise in low range #12
If you found a piece of gear tooth when you drained the transmission oil then you have identified the problem and yes using it in low range with a broken tooth will do more damage.
You can use the old wooden broom handle trick to get a general location of where the sound is actually coming from.
   / Transmission noise in low range #13
I can't help you with yours, but my 3000 diesel makes no noise in low or high range. So you definitely got something going on. I would really try and find where that piece of tooth or metal came from.
Thanks to everyone who responded.I’m getting a lot of experience working on this tractor.lol
   / Transmission noise in low range #15
Well once you get it all straightened out I hope you enjoy it as much as I like my 3000.
I got one more fall agricultural fair to attend with it, then I will also be pulling off the lift cover to change my filter and put new gasket and o-rings as my rear remote valve is leaking at the base.
Giyi 72" Grapple (A53316)
Giyi 72" Grapple...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
Year: 2012 Make: Audi Model: Q7 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 161335 Plate: B... (A55853)
Year: 2012 Make...
